[mapguide-users] hide layer on box checked
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Oct 25 07:42:33 EDT 2007
You cannot use the SessionID directly to access resources.
It must be used to build an URI like this:
"Session:<sessionid>//Map1.Map"
where "<sessionid>" is the value you get from GetSessionId().
This is mentioned on page 19 in the manual.
Regards, Kenneth, GEOGRAF A/S
dorra2007 skrev:
> I used this function to get the session ID :
> document.myform.session.value=parent.parent.mapFrame.GetSessionId();
> But I have this error:
> The session ID is invalid because the session separator character was not
> found
> Have you an idea about the "session separator"?
> Regards.
> Kenneth, GEOGRAF A/S wrote:
>> I assume that you do know that the code below is in Java/JSP and not
>> javascript.
>> The resourceService is created from the site, with CreateService.
>> I just tried to find the example in the HTML version of the manual, with
>> no luck, try the PDF version instead:
>> http://mapguide.osgeo.org/files/mapguide/docs/MgOpenSourceDevGuide.pdf
>> Page 36:
>> MgInitializeWebTier ($webconfigFilePath);
>> $userInfo = new MgUserInformation($mgSessionId);
>> $siteConnection = new MgSiteConnection();
>> $siteConnection->Open($userInfo);
>> $resourceService =
>>   $siteConnection->CreateService(MgServiceType::ResourceService);
>> $map = new MgMap();
>> $map->Open($resourceService, $mgMapName);
>> $layers = $map->GetLayers();
>> $roadLayer = $layers->GetItem('Roads');
>> $roadLabel = $roadLayer->GetLegendLabel();
>> if ($roadLabel == 'Roads')
>> $newLabel = 'Streets';
>> else
>> $newLabel = 'Roads';
>> $roadLayer->SetLegendLabel($newLabel);
>> // You must save the updated map or the
>> // changes will not be applied
>> // Also be sure to refresh the map on page load.
>> $map->Save($resourceService);
>> On-top-of-my-head translation to jsp:
>> MgInitializeWebTier (webconfigFilePath);
>> MgUserInformation userInfo = new MgUserInformation(mgSessionId);
>> MgSiteConnection siteConnection = new MgSiteConnection();
>> siteConnection.Open(userInfo);
>> MgResourceService resourceService =
>>   siteConnection.CreateService(MgServiceType::ResourceService);
>> MgMap map = new MgMap();
>> map.Open(resourceService, mgMapName);
>> MgLayerCollection layers = map.GetLayers();
>> MgLayer roadLayer = layers.GetItem('Roads');
>> roadLabel = roadLayer.GetLegendLabel();
>> String newLabel;
>> if (roadLabel == "Roads")
>> newLabel = "Streets";
>> else
>> newLabel = "Roads";
>> roadLayer.SetLegendLabel(newLabel);
>> map.Save(resourceService);
>> dorra2007 skrev:
>>> Hi all;
>>> I have read several posts about the setvisible function, but I have still
>>> errors in my code  (I am using javascript/jsp).
>>> Can someone give me a comprhensive code in javascript, wich show how i
>>> can
>>> use the SetVisible method?
>>> PS: My featuresource is a postgis database.
>>> here is the code i used:
>>> map=new MgMap();
>>> map.open(resourceService,map_name);
>>> layer=map.GetLayers().GetItem(layer_name);
>>> layer.SetVisible(true);
>>> map.save(resourceService);
>>> the resourceService is not defined. In fact, what does it refers to?And
>>> how
>>> can I define it?Should I create a map object?..
>>> Many question, can someone help me?
>>> Thank you in advance.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071025/dbf636fc/attachment.html
