[mapguide-users] Fluctuating Cursor Accuracy
IT-Joe Marvin JMarvin at redwoodcity.org
Wed Oct 31 14:03:09 EDT 2007
So I gather then that there is nothing the developer can do to detect or
stop this.  Do you know if a bug report been filed?  I looked through
and do not see anything.  If not, I will submit one.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Tuesday, October 30, 2007 4:44 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Fluctuating Cursor Accuracy
We get this problem sometimes, the whitespace causes displacement of the
map,
throwing off the accuracy of the selection tools.
If you resize any part of the ajax viewer that would cause a resize of
the
map pane, the whitespace will disappear and your selection accuracy
should
be restored.
- Jackie
joecm wrote:
> Yes there is.
> -joe
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Tuesday, October 30, 2007 3:54 PM
> Subject: Re: [mapguide-users] Fluctuating Cursor Accuracy
> Is there whitespace at the top of your AJAX viewer? (below the
toolbar)
> - Jackie
> joecm wrote:
>> When using an AJAX map, cursor is not always aligned properly.
>> For example,  if I go to select a polygon, sometimes the polygon on
> the
>> tail or middle of the cursor is selected, instead of the point of the
>> cursor.    It seems to vary each time I load the page, sometimes it
is
>> correct, other times it is not.  This is very confusing to users who
>> think they are clicking on one polygon and actually clicking on
> another.
>> Has anyone else encountered this problem, or even better, found a
fix?
>> Thanks
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
http://www.nabble.com/Best-method-to-use-dwg-files-tf4719897s16610.html#
> a13499525
> Sent from the MapGuide Users mailing list archive at Nabble.com.
a13500077
