[mapguide-users] MG studio 2007 can't cooperate with MG opensource 1.2.0 ? Update of Autodesk.MapGuide.Studio.Site.dll is not enough?
Carl carlshe at 163.com
Sun Sep 9 06:37:50 EDT 2007
I found also the error copying the fdo files. I reinstalled the MG studio and
patchit accordingly, and copy the client library of ArcSDE92 to FDO
directory.
Now the studio can load most types of data files except DWG (It seems
something is wrong with Autodesk Dete.exe. I looked from website of
autodesk, but not get to a solution). A new problem is : I can't connect to
arcsde92 installed on local machine. Then i try to connect arcsde92 on
another machine. Ok. it works. but no featureclass inside the ArcSDE server
can be listed out. so no real featuresource can be made. In conclude, there
are two strange phenomena : one is about autodesk dete.exe, and another is
about the ArcSDE 9.2.
Regards. SHE
Kenneth, GEOGRAF A/S wrote:
> You should NOT copy any of the FDO files into the studio folders.
> The FDO folder in the Studio installation is only used with som internal
> studio operations, and has no effect on the server's FDO capabilities.
> You must modify the providers.xml file that is located in the mapguide
> folder (C:\program files\mapguideopensource\server\bin\fdo)
> After modifying the file, you must restart the mapguide service.
> Studio caches the providers, so you must restart studio as well.
> In your case, I would recommend uninstalling Studio, and repeating the
> install/patch procedure.
> Regards, Kenneth, GEOGRAF A/S
> Carl skrev:
>> I just had installed MG opensource 1.2, and patched autodesk mg studio
>> 2007
>> accordingly (Initial Installation + SP1 + SP1a +
>> Autodesk.MapGuide.Studio.Site.dll Patch). I also copied all files located
>> in
>> the bin/fdo of mg Opensource 1.2 server to FDO directory of studio 2007
>> and
>> modified the providers.xml. But when new a load procedure or a data
>> connection, the shown list are still the previous items, no any provider
>> in
>> the providers.xml is listed.
>> Now the studio can only deal with previously existing data, layer and
>> layout. once to load or connect new data source, the problem would be
>> popup,
>> 'Unable to complete request to site','An exception occurred in FDO
>> component. Failed to open ArcSDE connection. ', and so on,  Except that
>> DWF
>> can be loaded.
>> The studio can worked very well with the MG OS 1.1 before, is it not
>> compatible with MG OS 1.2 ? or it need much more patches?
>> please help me. thank you very much. Now I am urgently waiting to dealing
>> with new map data.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/MG-studio-2007-can%27t-cooperate-with-MG-opensource-1.2.0---Update-of-Autodesk.MapGuide.Studio.Site.dll-is-not-enough--tf4406674s16610.html#a12577729
