[mapguide-users] MGOS 1.2 mgserver.exe
Fri Sep 14 08:43:22 EDT 2007
Kym Ralph wrote:
> Hi Frank
> I convert all the ecw files to tiffs using the fwtools and I don't have
> the problem with the mgserver.exe becoming unresponsive. The real
> problem seems to occur when mapguide is accessing a group of 123 ecw
> files in one directory, the other directories of only 5-10 ecw files
> work fine. I created all the image datasets using Jason's
> rasterconfig.php tool. Is there any way to capture the ecw errors as
> running mgserver in debug mode doesn't return any errors, so I can feed
> it into the FDO trac ticket??
Kym,
If you run MgServer in debug mode and also define the CPL_DEBUG environment
variable to be YES there may be additional output.  But if the problem is
deep in the ECW SDK and not being reported we may not find out anything
useful.
I hate problems that only manifest with many files ... very hard to debug!
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
