[mapguide-users] MGOS 1.2.0 Filter On Joined Field
Krunoslav a_krunoslav at gmx.net
Mon Sep 17 17:52:38 EDT 2007
James Card wrote:
> I just tested again on MGOS 1.2.0 and am still not able filter a layer on
> a field from a joined table (for example, the expression '"Join1ClassRoom"
> = TRUE' does not work). I was sure that we've discussed here before, and
> even thought that it had been fixed, but I just searched through Trac and
> did not find a ticket on this.
> Is this feature working working for others (which would indicate that I
> have simply misconfigured my filter definition)?
I don't know if this is same problem as mine (posted 20 mins ago), but it
seems so. So you are not alone on this.
View this message in context: http://www.nabble.com/MGOS-1.2.0-Filter-On-Joined-Field-tf4470070s16610.html#a12745898
