[mapguide-users] MGOS 1.2.0 Filter On Joined Field
Rahul unicorn_admirer at yahoo.com
Wed Sep 19 13:33:13 EDT 2007
         Filter will only work on the primary source although you can show values coming from the secondry source in the properties pane,but filtering will not work on the secondry source like SQL views,ODBC DataSource etc.
  Example -
                   SDF(Primary)+ODBC(Secondry)
  Filtr possible only on SDF and not possible on columns coming from Secondry source.
  Cheers
  Max !!
Jorge Rubio <j.e.rubio at gmail.com> wrote:
  Are you using SDF2? Are you joining two key fields?
  2007/9/19, James Card <James.Card at calcad.com>:   On Wed, 19 Sep 2007 09:01:54 -0700, Jorge Rubio <j.e.rubio at gmail.com >
wrote:
> What are you trying to do?
> Do you want filter data in Studio to set properties values to layers?
> Do you want filter data by code -inside an application- to modify
What we need to do is store the geometries in SDF files and then display
only the polygons from that SDF where the matching database record has
some value. For example, in this layer display only the rooms where
TYPE='LAB' and SIZE<300. This works fine as long as all the data is stored
in the SDF, but we can't filter on fields from a joined table (even though
the fields from the joined table are visible in the Properties pane, so we
know the join is working).
James Card
209-578-5580
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Lic. Jorge Rubio _______________________________________________
 Check out  the hottest 2008 models today at Yahoo! Autos.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070919/59275d6f/attachment.html
