[mapguide-users] RE: changing task frame position
Ivan Milicevic Ivan.Milicevic at supranet.hr
Mon Sep 24 06:58:36 EDT 2007
Lool at framesettaskbar.templ in viewerfiles direcotry....
From: mapguide-users-bounces at lists.osgeo.org on behalf of dorra labidi
Sent: sub 22.9.2007 12:02
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: changing task frame position
Hi Jason;
"is that possible to change the position of the task pane to the left side instead of right side (original position)?
if yes, can I know how to change it?"  (Kencana's question)
I have followed the steps you have indicated in this subject and when I run the application, I obtain the following :
/mapguide/mapviewerjava/viewoptions.jsp
written on the web page!!!!!!!!
I think that there might be another changes to do,
"Finally, you'll need to do something with the styling to make the task
pane stand out from the legend/properties."------>What Shall I do?
_______________________________________________________________
*	Van: Jason Birch [mailto:Jason.Birch at nanaimo.ca <http://lists.osgeo.org/mailman/listinfo/mapguide-users> ]
	Verzonden: vrijdag 3 november 2006 10:10
	Aan: users at mapguide.osgeo.org <http://lists.osgeo.org/mailman/listinfo/mapguide-users>
	Onderwerp: RE: [mapguide-users] changing task frame position
	Yes, but it's not easy.  To do so, you will need to understand how the
	current templating system works.
	How the template system works is that the mapviewer files use the
	sprintf() function to do variable substitution into a static text file,
	and output that as HTML.  I'll give an example for the PHP mapviewer.
	In this case, the mainframe.php file figures out a bunch of stuff like
	the size of your frame, whether you want the task frame to show, and
	some other stuff.  If you do want the task frame to show, then it calls
	some code around line 435 that swaps a whole bunch of variables (20)
	into the framesettaskbar.templ file.
	To move the task pane to the left side, you will need to both modify the
	"framesettaskbar.templ" file (it's in www\viewerfiles\) and the
	mainframe.php file (it's in www\mapviewerphp\).
	First, you have to change the HTML template in the framesettaskbar.templ
	file.  You need to change the order of the "taskArea" and the "maparea"
	framesets, and also change the "cols" definition in their containing
	frameset from "*,%s" to "%s,*" so that the task area's width comes
	first.
	Next, you have to change the order that the variables are replaced into
	the template in the mainframe.php file.  For this, you will need to find
	the line that looks like "if($showTaskBar)".  A couple lines down from
	that, is the call that generates the frameset that includes the task
	bar.  Take "$toolbarHeight+1,",  "$srcTaskBar," and "$srcTaskFrame," and
	move them up until they are between the "$taskWidth," and
	"$toolbarHeight," variables in the sprintf() call.
	Hope this helps,
	Jason
Ne gardez plus qu'une seule adresse mail ! Copiez vos mails <http://www.trueswitch.com/yahoo-fr/>  vers Yahoo! Mail
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070924/ee6718fe/attachment.bin
