[mapguide-users] MapGuide integration with Google Maps
m.karam m21384k at yahoo.com
Tue Sep 25 08:03:58 EDT 2007
Hi
actually i need to show a base layer such as (a world layer) under my map
layers in the mapguide viewer.
is there any alternative solution instead of google maps?
Thank you for reply
Karam
macieksk wrote:
> hi
> if you add this to google maps you should use google api (it is much
> easy as api in MG)
> guestion is how many layers did you whant to show?
> If one ex. parcels you should create KML or even simple txt file and put
> it into google maps. Just use  (look into google API FAQ)
> var geoXml = new GGeoXml("url_to_kml_files");
> if you look on internet you should find many of examples how to use kml
> files whit polygon,poliline etx. whit google maps.
> Maciej Skórczewski
> m.karam pisze:
>> Hi
>> If i add mapguide layers to google maps, will i able to use the mapguide
>> viewer without any changes in my code ?
>> thanks for your reply
>> Karam
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/MapGuide-integration-with-Google-Maps-tf4513885s16610.html#a12878086
