[mapguide-users] postgis connection properties EMPTY!!!!!
dorra2007 dorrdor at yahoo.fr
Wed Sep 26 05:07:05 EDT 2007
Problem resolved:
there is DLL's missing: comerr.dll, krb5.dll,
libintl-2.dll,visnint.dll,msvcp80.dll, to be copied in the FDO folder
msjava.dll, libeay32.dll and ssleay32.dll....to be copied in the system32
folder
Kenneth, GEOGRAF A/S wrote:
> The problem is that the PostGIS FDO Provider (as well as the other
> providers) depend on certain Dll's being avalible.
> I recommend using dependency walker to open the Dll, and view it
> dependencies. It will highlight missing dll dependencies.
> http://www.dependencywalker.com
> Regards, Kenneth, GEOGRAF A/S
> dorra2007 skrev:
>> I have tried this steps. I have successfully connected to postgis with
>> windows XP home. Now I am using WinLSD and i wanted to redo exactly the
>> same
>> steps, but I failed. I have always the 4 fields empty, no data to enter
>> and
>> of course, can't establish connection to postgis.
>> Does the problem come from the operating system I use?
>> macieksk wrote:
>>> Try this steps.
>>> 1. Install MG 1.2 Stable version
>>> 2. Install Postgres 8.2.xx (), after that instal postgis extension.
>>> 3. Download PostgGIS provider
>>> 4. change provider.xml file in
>>> C:\Program Files\MapGuideOpenSource\Server\Bin\FDO
>>> (add this
>>>   <FeatureProvider>
>>>      <Name>OSGeo.PostGIS.3.2</Name>
>>>      <DisplayName>OSGeo FDO Provider for PostGIS</DisplayName>
>>>      <Description>FDO Provider for PostGIS</Description>
>>>      <IsManaged>False</IsManaged>
>>>      <Version>3.2.0.0</Version>
>>>      <FeatureDataObjectsVersion>3.2.0.0</FeatureDataObjectsVersion>
>>>      <LibraryPath>PostGISProvider.dll</LibraryPath>
>>>    </FeatureProvider>
>>> 5. restart serwer.
>>> 6. open Mg Studio->create new data connection->(in this place ypu should
>>> have Postgis provider) -> if all is ok you should have 4 fields to enter
>>> connection string.
>>> dorra labidi pisze:
>>>> Hi every body;
>>>> I have reinstalled mapguide OS, web Studio and postgresql/postgis on my
>>>> computer. I have also copied the postgisfdo provider DLL's and modified
>>>> the providers.xml file. Finally I have copied the postgis bin folder to
>>>> the bin folder of mapguide server OS.
>>>> When I clic on "configure data connection", I find the postgis porvider
>>>> in the list of providers.
>>>> *The problem is that the "connection properties" fields are empty*:
>>>> There is no username field nor password, schema and source  field.
>>>> The error message is :
>>>> /An exception occurred in FDO component.
>>>> Unable to load the FDO Provider: /
>>>> Has anyone encountred this problem?
>>>> Thank you very much for your help.
>>> Maciej Skórczewski
>>> PROCAD SA
>>> Autodesk Authorized Value Added Reseller
>>> www.procad.pl
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/postgis-connection-properties-EMPTY%21%21%21%21%21-tf4514993s16610.html#a12896900
