[mapguide-users] RE: RE: Layer Projection
Traian Stanev traian.stanev at autodesk.com
Fri Sep 28 12:04:54 EDT 2007
Hmmm. The only projected coordinate systems with the Luzon datum I see
in the PROJ list are
25391,"Luzon 1911 / Philippines zone
I",9001,4253,18171,9807,1,0,8801,0,9102,8802,117,9102,8805,0.99995,9201,
8806,500000,9001,8807,0,9001,,,,,,
25392,"Luzon 1911 / Philippines zone
II",9001,4253,18172,9807,1,0,8801,0,9102,8802,119,9102,8805,0.99995,9201
,8806,500000,9001,8807,0,9001,,,,,,
25393,"Luzon 1911 / Philippines zone
III",9001,4253,18173,9807,1,0,8801,0,9102,8802,121,9102,8805,0.99995,920
1,8806,500000,9001,8807,0,9001,,,,,,
25394,"Luzon 1911 / Philippines zone
IV",9001,4253,18174,9807,1,0,8801,0,9102,8802,123,9102,8805,0.99995,9201
25395,"Luzon 1911 / Philippines zone
V",9001,4253,18175,9807,1,0,8801,0,9102,8802,125,9102,8805,0.99995,9201,
I can't find a pre-defined Zone 50 with your datum. So you may have to
create your own WKT string for that coordinate system. Or, if all your
data are using the same coordinate system, you can just try using an
arbitrary XY coordinate system.
Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of emviado
> Sent: Friday, September 28, 2007 1:27 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] RE: RE: Layer Projection
> No .prj file but, I was just informed that the coordinate properties
> are:
> Projection: UTM Zone50N
> Datum: Luzon 1911
> Units: Decimal Degrees
> Spheroid: Clarke Spheroid of 1866
> emviado
> Traian Stanev wrote:
> > Does your SHP file have an associated .PRJ file?
> > Traian
> >> Sent: Thursday, September 27, 2007 11:05 AM
> >> Subject: [mapguide-users] RE: Layer Projection
> >> Thanks for the prompt help Traian. NAD 27 is the North American
> Datum.
> >> I
> >> should have mentioned that the shapefile I want to import is in
> >> Palawan,
> >> Philippines.
> >> emviado
> >> > Look for a UTM projection that uses the NAD 27 datum. NAD 27 uses
> > the
> >> > Clarke ellipsoid. If the SHP file has an associated PRJ file, it
> >> should be
> >> > automatically recognized.
> >> > Traian
> >> > 	From: mapguide-users-bounces at lists.osgeo.org on behalf of
> >> Emmanuel Viado
> >> > 	Sent: Wed 9/26/2007 8:56 PM
> >> > 	Cc:
> >> > 	Subject: [mapguide-users] Layer Projection
> >> > 	Hi,
> >> > 	Just starting to use MGO 1.2. I want to import a shapefile in
> > UTM
> >> Zone
> >> > 50, Clarke 1866 ellipsoid projection. What projection in MGO do I
> > use
> >> to
> >> > bring in the file?
> >> > 	Thanks,
> >> > 	emviado
> >> >   _____
> >> > 	Got a little couch potato?
> >> > 	Check out fun summer activities for kids.
<http://us.rd.yahoo.com/evt=48248/*http://search.yahoo.com/search?fr=on
> >> i_on_mail&p=summer+activities+for+kids&cs=bz>
> >> > _______________________________________________
> >> > mapguide-users mailing list
> >> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> >> View this message in context: http://www.nabble.com/Layer-
> Projection-
> >> tf4525784s16610.html#a12923153
> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
> View this message in context: http://www.nabble.com/Layer-Projection-
> tf4525784s16610.html#a12934872
