[mapguide-users] Re: How to Create a layerDefinitionprogrammtically , using xml?
Brad L bradl at mai-eng.com
Sat Sep 29 01:01:42 EDT 2007
This may or may not make a difference.  I am mentioning it because it is the
only difference that I can find from the method that works for me.  Is there
a reason to use MGLayerBase instead of MGLayer?  I think someone pointed out
that it could be an inheritance issue.
Brad Leighninger
Mathews & Associates, Inc.
417-869-6009
Champin wrote:
> Brad L,您好!
> 	Thanks for your help,Brad!
> 	Actually, My used the DOM-processing method the create the layer
> definition exactly like the code you provided, they run well and created
> the MgLayer object successfully, but the following steps (step 4 ,as I
> mentioned first mail)  ,the map.Save(resourceService) will raise the
> MgNotImplementedException, So I changed to the string-processing way to
> create layerdefinition. Both XML-processing and string-processing can
> create the layerdefiniton and create the MgLayer object successfully ,and
> both of them get the same exception in the following step---map.Save(...).
> ======= 2007-09-29 03:19:42 您在来信中写道:=======
>>Try this
>>public MgLayer CreateTrackLineLayer(String rootPath, MgResourceService
>>resService, MgResourceIdentifier TrackResId, String sessionId)
>>        // Load the TrackLinelayerdefinition template into
>>        // an ASPX XML object, find the "ResourceId" element, and
>>        // modify it's content to reference the feature source.
>>        XmlDocument doc = new XmlDocument();
>>        doc.PreserveWhitespace = true;
>>        doc.Load(rootPath + @"\Template\TrackLineLayerDefinition2.xml");
>>        XmlNode featureSourceNode =
>>doc.GetElementsByTagName("ResourceId").Item(0);
>>        XmlNode resContent = doc.CreateTextNode(TrackResId.ToString());
>>        featureSourceNode.AppendChild(resContent);
>>        // Get the updated layer definition from the DOM object
>>        // and save it to the repository using the
>>        // ResourceService object.
>>        MemoryStream xmlStream = new MemoryStream();
>>        doc.Save(xmlStream);
>>        byte[] layerDefinition = xmlStream.ToArray();
>>        Encoding utf8 = Encoding.UTF8;
>>        String layerDefStr = new String(utf8.GetChars(layerDefinition));
>>        layerDefinition = new byte[layerDefStr.Length - 1];
>>        int byteCount = utf8.GetBytes(layerDefStr, 1, layerDefStr.Length -
>>1, layerDefinition, 0);
>>        MgByteSource byteSource = new MgByteSource(layerDefinition,
>>layerDefinition.Length);
>>        byteSource.SetMimeType(MgMimeType.Xml);
>>        //this stores it to the session but you could pass your
>>MgResourceIdentifier as you did in your code
>>        MgResourceIdentifier tempLayerResId = new
>>MgResourceIdentifier("Session:" + sessionId +
>>"//TrackLineLayer.LayerDefinition");
>>        resService.SetResource(tempLayerResId, byteSource.GetReader(),
>>null);
>>        // Create an MgLayer object based on the new layer definition
>>        // and return it to the caller.
>>        MgLayer newLayer = new MgLayer(tempLayerResId, resService);
>>        return newLayer;
>>I didn't debug this but it should get you in the ball park.
>>Brad Leighninger
>>417-869-6009
>>Champin wrote:
>>> How to Create a layerDefinition programmtically , using xml?
>>> Here is my steps, but something wrong happened,
>>> raised when added the layer to the map and Map.Save()
>>> 1.Using MapGuide Studio, Open an LayerDefinition , File --> Save as xml;
>>>    in fact, I want to create temp layer the same as the existing layer
>>> ,so
>>> , the temp layers' layerDefinition should be the same as the existing
>>> layer,except the <ResourceID>.....</ResourceID>
>>> 2. Change the resourceId to the replace flage ,such as <ResourceID>
>>> %resourceID</ResourceID> and save the xml as
>>> layerDefinitionTemplate.xml
>>> 3.Create the Layer
>>>  public MgLayerBase CreateTrackLineLayer(String rootPath,
>>> MgResourceService resService, String featureSourceName,
>>> MgResourceIdentifier LayerId)
>>>         MgLayerBase newLayer = null;
>>>         //字符串方法
>>>         string layerDefinition = File.ReadAllText(rootPath +
>>>         layerDefinition = layerDefinition.Replace("%resourId",
>>> featureSourceName);
>>>         MgByteReader reader = new MgByteReader(layerDefinition,
>>> "text/xml");
>>>         resService.SetResource(LayerId, reader, null);
>>>         newLayer = new MgLayerBase(LayerId, resService);
>>>         return newLayer;
>>>    these code goes well while debuging
>>>  4. Added the layer to the map and save .
>>>             MgLayerBase TrackLineLayer =  CreateTrackLineLayer(.......);
>>>              // 设置层属性
>>>             TrackLineLayer.SetName("TrackLineLayer");
>>>             TrackLineLayer.SetDisplayInLegend(true);
>>>             TrackLineLayer.SetLegendLabel("航迹");
>>>             TrackLineLayer.SetVisible(true);
>>>             TrackLineLayer.ForceRefresh();
>>>             map.GetLayers().Insert(0, TrackLineLayer);
>>>         // add some feature to the layer feature source
>>> 	 MgPropertyCollection props =BuildeNewPropCollection(.......);
>>>         MgFeatureCommandCollection commands = new
>>> MgFeatureCommandCollection();
>>>         commands.Add(new MgInsertFeatures(featureName, props));
>>>         featureService.UpdateFeatures(TrackLineFeatureSourceID,
>>> commands,
>>> false);
>>>        //Save the map
>>>         TrackLineLayer.SetSelectable(true);
>>>          map.Save(resService);  //**** ERROR
>>> 	    here raise the Exception  " MgNotImplementedException "
>>> Can you tell me what am I doing wrong?  I have been blocked here for a
>>> whole day, any suggestion will be very appreciate .
>>> Thank you !
>>> My envionment :
>>> Windows XP SP2
>>> VS2005 .net 2.0  + MapGuide Open Source 1.2
>>View this message in context:
http://www.nabble.com/How-to-Create-a-layerDefinition-programmtically-%2C-using-xml--tf4514122s16610.html#a12946832
>>Sent from the MapGuide Users mailing list archive at Nabble.com.
>>_______________________________________________
>>mapguide-users mailing list
>>mapguide-users at lists.osgeo.org
>>http://lists.osgeo.org/mailman/listinfo/mapguide-users
>         致
> 礼!
>         champingfor
>         champingfor at 163.com
>           2007-09-29
> MapGuide Developer Network(China)
> http://www.mgdn.com.cn
View this message in context: http://www.nabble.com/How-to-Create-a-layerDefinition-programmtically-%2C-using-xml--tf4514122s16610.html#a12952223
