[mapguide-users] ODBC and regional settings
Ismael Cams mapguide2007 at gmail.com
Tue Apr 1 16:07:16 EDT 2008
Hello,
I am using MGOS 1.2 and encountered a problem when reading coordinates out
of an Access database. The coordinates are shown correctly by MGOS on one of
our servers which has regional settings US. The client PCs that we are using
for development however have Dutch regional settings and we noticed that
with the identical database not all records where returned. We also
discovered the returned coordinates were displayed outside the expected
bounds.
After I did a conversion from the datatype of the geometry columns (decimal
to long integer) the problem was solved. So it seems that MGOS can not
handle with decimal numbers when the regional settings are US different ...
Can this be tracked as a bug ?
View this message in context: http://www.nabble.com/ODBC-and-regional-settings-tp16423311s16610p16423311.html
