[mapguide-users] MGOS 2.0: Problem consuming WFS still exists
Ismael Cams mapguide2007 at gmail.com
Thu Apr 3 08:00:19 EDT 2008
Hello,
I tried the same procedure with MGOS 2.0 but the result is the same.
Is this a bug (and can it tracked) or could it be a problem of the published
WFS ?
Ismael Cams wrote:
> Hello,
> I am using MGOS 1.2 and trying to consume WFS from following server:
> http://www.gegis.org/gegis-1.2/wfs?
> Although the layers and attributes are shown correctly in Mapguide Studio
> I am not able to show the geometry. In the error.log there is following
> error message:
>    Error: Failed to stylize layer: LayerDefinition3
>         An exception occurred in FDO component.
>         Schema can not be found in the collection.
> In order to check if it might be a problem with the WFS server itself, I
> have tried some other servers on the Internet too. But result is always
> the same, no geometry is shown ...
> Is this a result of GML inconsistencies ?
> Can someone point me in the right direction what should be done to get the
> connection working ?
> Thanks in advance.
View this message in context: http://www.nabble.com/Mapguide-and-consuming-WFS%3A-does-it-work-for-someone---tp16180546s16610p16467427.html
