[mapguide-users] MGOS 2.0: Problem consuming WFS still exists
Jason Birch Jason.Birch at nanaimo.ca
Thu Apr 3 15:50:21 EDT 2008
There is an issue with consumption of WMS in MGOS 2.0.
http://trac.osgeo.org/mapguide/ticket/492
It's been fixed in the 2.0 branch, but a binary fix isn't available yet.
This is different than the issue that Don is seeing, which is the
consumption of MapGuide 2.0 WFS services, although the bug could be on
the Map3D FDO WMS Provider which would make it similar.  Don, can you
run something like Fiddler to view the interaction between Map and
MapGuide?
If you could document the problem, preferably with an MGP package that
could be easily loaded to duplicate the problem, that would be great:
http://trac.osgeo.org/mapguide/wiki/SubmitTicket
Be sure to include information on your MapGuide server setup (operating
system, if you're using a non-US locale on the server, versions, etc).
Jason
-----Original Message-----
Subject: Re: [mapguide-users] MGOS 2.0: Problem consuming WFS still
exists
Did you succeed with other WFS servers ? I did try some other online WFS
servers but without any result ...
Don C. MacGregor wrote:
> I am running MGOS 2.0 and can successfully connect to WFS server using
> AutoCAD Map 3D 2008 but there is nothing in the list of layers.
