[mapguide-users] Problem with .NET
Sandeep Thosar sandeepthosar at gmail.com
Thu Apr 3 23:28:16 EDT 2008
Dear  Jason,
First up of all thanks for your reply.
I have .NET Framework 2005 and   i installed OpenSource as per your
instructions provided in developer guide.
When i run the application i got number of errors in utilityfunction.aspx
for Ex. not a valid function or n number of syntax error then i use %@Page
Languge"C#"% on utilityfunction.aspx form  then all error realted to syntax
are solved but stilled i could not run the application and i received error
There can be only one 'page ' directive and validation(): element "html"
occurs too few times.
I checked all source code but i did not get any duplication.
Please help me out.
Thanks and Regards,
Sandeep
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080404/d1cc2856/attachment.html
