[mapguide-users] MGOS 2.0: MgUpdateFeatures broken
Maksim Sestic max at geoinova.com
Fri Apr 4 08:23:02 EDT 2008
Hi Ismael,
In case you're using managed wrapper, you may consider reading following
thread on FDO wiki:
http://www.nabble.com/.net-Wrapper-quirks-to16318694s18162.html
including related Ticket:
http://trac.osgeo.org/fdo/ticket/284
Regards,
Maksim Sestic
Ismael Cams wrote:
> You are right. It was indeed a FeatureReader problem. I was closing it,
> but only after having done the update. Somehow it did not give problems in
> MGOS 1.2.
> I have moved the close() before the deletion/update of the feature and it
> is working fine now.
> Thanks for the help.
> zspitzer wrote:
>> if your refering to the thread 'Please try your operation later as the
>> resource was busy' from Adam
>> it was indeed a feature reader problem
>> On Fri, Apr 4, 2008 at 5:45 PM, Ismael Cams <mapguide2007 at gmail.com>
>> wrote:
>>>  The featurereader is closed. The identical code is behaving correct on
>>> MGOS
>>>  1.2.
>>>  There is a parallel thread on the forum at the moment which is
>>> describing
>>>  the same problem withe updating and deleting features. Might be a bug
>>> or
>>>  changed behaviour ?
>>>  did you open a feature reader and not close it?
>>>  View this message in context:
>>> http://www.nabble.com/MGOS-2.0%3A-MgUpdateFeatures-broken-tp16467463s16610p16485938.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>  _______________________________________________
>>>  mapguide-users mailing list
>>>  mapguide-users at lists.osgeo.org
>>>  http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
View this message in context: http://www.nabble.com/MGOS-2.0%3A-MgUpdateFeatures-broken-tp16467463s16610p16491260.html
