[mapguide-users] Preserve Session Data to Restore after Service Restarts?
Dave Wilson dave.wilson at autodesk.com
Wed Apr 9 13:20:43 EDT 2008
It might not yield much, but can you check the access logs just prior to the crash to see if you can see a pattern in calls that might be causing the crash?
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Steve Dang
Sent: Wednesday, April 09, 2008 11:04 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Preserve Session Data to Restore after Service Restarts?
Could you log this defect with details on how to reproduce the problem?
About the session data, could you enter that as an enhancement (MGOS currently does not support it)?
Thanks,
Steve.
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of nclayton
Sent: Wednesday, April 09, 2008 10:38 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Preserve Session Data to Restore after Service Restarts?
Hi everyone.
I have an issue of mgserver.exe crashing with Event ID: 0 errors, and the
only solution that I have found to this problem is to schedule a batch file
to run to kill the service then restart it.
It's currently set to run every 30 minutes and I may need to reduce the time
more...
My question is this: Is there a way to "save" user session data out
somewhere before I kill the service, then "read" it back in after the
restart so my users can continue what they're doing instead of having their
viewer just stop working?
View this message in context: http://www.nabble.com/Preserve-Session-Data-to-Restore-after-Service-Restarts--tp16590557s16610p16590557.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
