[mapguide-users] Preserve Session Data to Restore after Service Restarts?
nclayton nclayton at gmail.com
Wed Apr 9 15:58:14 EDT 2008
I received this Application Error when the service crashed:
Event Type:	Error
Event Source:	Application Error
Event Category:	(100)
Event ID:	1000
Date:		4/9/2008
Time:		2:24:55 PM
Description:
Faulting application mgserver.exe, version 2.0.0.2308, faulting module
ntdll.dll, version 5.2.3790.3959, fault address 0x0002c853.
and these were recorded in Error.log for MapGuide:
<2008-04-09T14:24:31> 			Anonymous
 Error: An unclassified exception occurred.
 StackTrace:
  - MgRenderingServiceHandler.ProcessOperation line 83 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
  - MgOpQueryFeatures.Execute line 125 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
  - MgServerRenderingService.QueryFeatures line 647 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\rendering\ServerRenderingService.cpp
  - MgServerRenderingService.RenderForSelection line 1252 file
<2008-04-09T14:24:34> 			Anonymous
 Error: Failed to stylize layer: covcitylimitstxt
 StackTrace:
  - MgMappingUtil.StylizeLayers line 776 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\mapping\MappingUtil.cpp
 Error: Failed to stylize layer: twprngtxt
 StackTrace:
 Error: Failed to stylize layer: aerial
 StackTrace:
And this is the only Failure in the Access.log for the time period:
QueryFeatures.1.0.0:7(Session:6d816b5e-0000-1000-8000-00034732c825_en_7F0000010AFC0AFB0AFA//county.Map,MgStringCollection,MgGeometry,4,,1,5)
Failure
nclayton wrote:
> Hi everyone.
> I have an issue of mgserver.exe crashing with Event ID: 0 errors, and the
> only solution that I have found to this problem is to schedule a batch
> file to run to kill the service then restart it.
> It's currently set to run every 30 minutes and I may need to reduce the
> time more...
> My question is this: Is there a way to "save" user session data out
> somewhere before I kill the service, then "read" it back in after the
> restart so my users can continue what they're doing instead of having
> their viewer just stop working?
View this message in context: http://www.nabble.com/Preserve-Session-Data-to-Restore-after-Service-Restarts--tp16590557s16610p16595203.html
