[mapguide-users] King Oracle Problem
Luis Rafael Ramos Correia LRRamos at aurensis.com
Thu Apr 10 05:46:52 EDT 2008
I tested de DependencyWalker on the KingOracleProvider.dll and it seemed to be missing the MSVCR80.dll and the MSVCP71.dll.
I searched and donwloaded this files from the web.
After that, the connection propreties on Autodesk Studio displayed well and i managed the connection to the database.
Thank you for your help.
Luís Ramos
Dpto. de GIS, Movilidad y Datos
-----Mensaje original-----
De: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] En nombre de Simon Pelicon
Enviado el: dijous, 10 / abril / 2008 11:43
Para: MapGuide Users Mail List
Asunto: Re: [mapguide-users] King Oracle Problem
Hi!
Connection properties are blank because provider did not loaded successfully.
Open  KingOracleProvider.dll with DependencyWalker ( http://www.dependencywalker.com/) and look for missing dll.
I think that Oracle client needs some Microsoft MFC dll files.
Simon
Luis Ramos wrote:
Hello,
I'm facing a similar problem on a XP machine with MagGuide Server 2.0,
Apache 2 and Oracle 9.2.
What I've done:
- downloaded and installed the King Oracle v.0.7.3 For FDO 3.3 with Oracle
Instant Client.
- downloaded and installed the Oracle Instant Client basic v 10.2.0.3
- changed the providers.xml file
- restarted the MapGuide Server
What do I get when creating a new data connection:
- on Autodesk MapGuide Studio 2008, shows the King Provider on the FDO list
but after selecting this, the connection properties are blank and non
editable.
- on AutoCAD Map 3D 2008, shows the King Provider on the FDO list but after
selecting this, I get an unable to create connection to provider
"King.Oracle.0.1.1".
If you managed to solve this problem please tell me how.
Luís Ramos
A H wrote:
	hello. i'm also currently facing the same problem. i'm using Oracle 9.2 as
	database. i followed the steps and i got this message when testing the
	connection in MapGuide Studio 2008:
	An exception occurred in FDO component.
	ORA-12705: Cannot access NLS data files or invalid environment specified
	what does that mean?
	my FDO version is 3.2.2. and i downloaded the v0.7.3 Windows 32-bit
	provider with Oracle Instant Client from the website. i copied the
	King.Oracle DLLs and Oracle instant clients DLL and put it in the FDO
	folder. is this definition correct for providers.xml?
	<FeatureProvider>
	             <Name>King.Oracle.0.1.1</Name>
	     <DisplayName>King Provider for Oracle</DisplayName>
	             <Description>Read/write access to spatial and attribute data in an
	Oracle Spatial.</Description>
	             <IsManaged>False</IsManaged>
	             <Version>0.1.1.0</Version>
	             <FeatureDataObjectsVersion>3.2.2.0</FeatureDataObjectsVersion>
	             <LibraryPath>C:\Program
	Files\MapGuideOpenSource\Server\Bin\FDO\KingOracleProvider.dll</LibraryPath>
	   </FeatureProvider>
	i thought everything should be fine since MapGuide Studio is enable to
	display the providers but i got that message. i use
	//[host]:1521/[service] as the service name as mentioned in the Oracle's
	documentation.
	Simon Pelicon wrote:
		Which version of MapGuide do you have?
		There are providers v0.7.3 for different FDO versions (3.1 ,3.2 and
		.3.2.2)
		Do you restart MG server after changing provider files,xml etc...?
		You can also check which files are missing or wrong , using "Dependency
		walker" http://www.dependencywalker.com/
		With Dependency W. open KingProvider.dll.
		Simon
		JeromeA wrote:
			yes I think so. I took the first one: v0.7.3 Windows 32-bit provider
			with
			Oracle Instant Client.
			I'm trying to connect to Oracle 9.2.0.4.0 from MG Studio 2008
			Jerome
		mapguide-users mailing list
		mapguide-users at lists.osgeo.org
		http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080410/f43e41a2/attachment.html
