[mapguide-users] MGOS 2.0 - mrsid problem...
Andrew DeMerchant andrew.demerchant at gemtec.ca
Mon Apr 14 16:11:17 EDT 2008
I'd tried a unc, and wasn't having success - so I thought I'd rule it
out by using the mapped drive, since I didn't know for sure that unc's
work. That said, I'd also tried using actual drive (the file server =
the mgos server) and also admin shares....none worked.
andrew
Dave Wilson wrote:
> In the MapGuide Enterprise stream of things we have found that mapped
> drives generally don't work for external resources. A UNC path
> \\servername <file:///%5C%5Cservername>\share\... does if the server
> login has share access. Of course this may not be the case with the
> gdal raster provider.
> Dave
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Andrew
> DeMerchant
> *Sent:* Monday, April 14, 2008 1:57 PM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] MGOS 2.0 - mrsid problem...
> N is indeed a network drive, but my other rasters are working fine
> using that drive letter. The mrsid is a couple of Mb - I'll email it
> to you....
> andrew
> Jason Birch wrote:
> Well, it all seems to match up OK.
> Are the other images on the same drive (wondering if N is a network
> drive)?
> Is the MrSID small enough that you'd be able to provide it to me
> offline (ftp or something)?
> Jason
> *From:* Andrew DeMerchant
> Resourcecontent:
> [snip]
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
