[mapguide-users] Unable to load DLL 'MapGuideUnmanagedApi'
Kenneth, GEOGRAF A/S ks at geograf.dk
Tue Apr 15 03:31:12 EDT 2008
I assume that you are trying to compile an ASP.Net WebApplication.
You can copy all the .dll files from the bin folder in the webserver
extensions into the bin folder of your project.
Other than that, I think the path is:
C:\Program Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\bin
It might work after your get a preview or start the viewer some other
way, because once the Dll is correctly loaded by some process, it is
avalible for the entire IIS application pool.
Regards, Kenneth, GEOGRAF A/S
cgrell skrev:
> I keep getting thie error randomly
> Unable to load DLL 'MapGuideUnmanagedApi': The specified module could not be
> found. (Exception from HRESULT: 0x8007007E)
> Everything will be working then I reboot the computer and this error starts
> to occur. I then reboot the computer, restart the web service, restart the
> mapguide service and recomile in a random order until the error finally goes
> away.
> I have added C:\Program Files\MapGuideOpenSource\WebServerExtensions\www to
> the path
> I am using MapGuide 1.2
> What might be causing this error and how can I troubleshoot this?
> Thank you
