[mapguide-users] .NET Fusion
Jackie C. Ng jumpinjackie at gmail.com
Thu Apr 17 15:38:24 EDT 2008
Is this executing from the task pane? If so, the initial url will receive the
MAPNAME get parameter from fusion. You can store it in your session bag
there.
- Jackie
Berdel, Brian wrote:
> Ok, I was setting that myself so that would make sense. So you have to
> grab the name programmatically then? You cannot specify yourself? I
> guess unless you know that ID.
> Brian  Berdel
> McMahon Associates, Inc.
> p: 215.283.9444
> www.mcmtrans.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie C.
> Ng
> Sent: Thursday, April 17, 2008 12:44 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] .NET Fusion
> The reason I ask is that fusion does map names differently from the
> normal
> ajax viewer. I think it's of the form [MapName][some long guid] instead
> of
> [MapName]
> - Jackie
>> Hi Jackie,
>> I am actually passing it via a session variable from another Sub.  It
> is
>> the correct value. And like I said the code does work in the regular
>> Ajax viewer.
>> String smgMap = (Session["smgMap"]).ToString();
>> Brian
> Ng
>> Sent: Wednesday, April 16, 2008 8:45 PM
>> Subject: Re: [mapguide-users] .NET Fusion
>> Where are you getting that value of the variable smgMap ?
>> - Jackie
>>> If I try to access a map via .net  fusion I always get this
>> error...Code
>>> works fine in regular viewer.   I have heard conflicting reports of
>>> Fusion and .NET can someone please clarify?
>>> MgUserInformation userInfo = new MgUserInformation(mgSessionId);
>>>         MgSiteConnection siteConnection = new MgSiteConnection();
>>>         siteConnection.Open(userInfo);
>>>         MgResourceService resourceService =
>>> siteConnection.CreateService(MgServiceType.ResourceService) as
>>> MgResourceService;
>>>         MgMap map = new MgMap();
>>>         map.Open(resourceService, smgMap);
>>> Resource was not found:
> Session:ba7530b4-ffff-ffff-800a-00142260e7d1_en_7F0000010AFC0AFB0AFA//So
>>> leburyTwp.Map
>>> Description: An unhandled exception occurred during the execution of
>> the
>>> current web request. Please review the stack trace for more
>> information
>>> about the error and where it originated in the code.
>>> Exception Details: OSGeo.MapGuide.MgResourceNotFoundException:
>> Resource
>>> was not found:
>>> leburyTwp.Map
>>> Source Error:
>>> Line 28:         MgResourceService resourceService =
>>> MgResourceService;
>>> Line 29:         MgMap map = new MgMap();
>>> Line 30:         map.Open(resourceService, smgMap);
>>> Brian Berdel
>>> p: 215.283.9444
>>> www.mcmtrans.com
>>> Brian Berdel
>>> Applications Development Manager
>>> 425 Commerce Drive, Suite 200
>>> Fort Washington, Pennsylvania 19034
>>> p: 215.283.9444
>>> f:  215.283.9858
>>> brian.berdel at mcmtrans.com
>>>   <http://www.mcmtrans.com>
>>>    New England  |  Mid-Atlantic  |  Florida
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://www.nabble.com/.NET-Fusion-tp16722611s16610p16736574.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> http://themapguyde.blogspot.com
> http://www.linkedin.com/in/jackieng
> http://www.nabble.com/.NET-Fusion-tp16722611s16610p16746611.html
View this message in context: http://www.nabble.com/.NET-Fusion-tp16722611s16610p16752349.html
