[mapguide-users] .NET Fusion
Mike Adair madair at dmsolutions.ca
Thu Apr 17 15:49:05 EDT 2008
Well perhaps I am misunderstanding something here then.  It is possible
that the MGOS side of things are running in a .NET environment, but
unless you have converted the PHP scripts in fusion/MapGuide/php to
.NET, I don't see how Fusion can run at all.  At a bare minimum you
would have to convert LoadMap.php, CreateSession.php and their includes.
In any case, the the map name is set as follows (in the PHP version of
LoadMap):
        $mapName = uniqid($mapTitle);
        $mapStateId = new MgResourceIdentifier("Session:" . $sessionID .
"//" . $mapName . "." . MgResourceType::Map);
where $mapTitle is the map name as set in MGOS and uniqid() returns a
unique ID based on the current time.
Mike
Berdel, Brian wrote:
> Mike it actually does because I am able to use the featurereader...I
> just cannot open a map.  Anyone know how to get the ID?
> Brian  Berdel
> McMahon Associates, Inc.
> p: 215.283.9444
> www.mcmtrans.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mike Adair
> Sent: Thursday, April 17, 2008 12:51 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] .NET Fusion
> Fusion itself doesn't run under .NET, at least as far as I know.
> Mike
> Jackie C. Ng wrote:
>> The reason I ask is that fusion does map names differently from the
> normal
>> ajax viewer. I think it's of the form [MapName][some long guid]
> instead of
>> [MapName]
>> - Jackie
>>> Hi Jackie,
>>> I am actually passing it via a session variable from another Sub.  It
> is
>>> the correct value. And like I said the code does work in the regular
>>> Ajax viewer.
>>> String smgMap = (Session["smgMap"]).ToString();
>>> Brian
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie C
> Ng
>>> Sent: Wednesday, April 16, 2008 8:45 PM
>>> To: mapguide-users at lists.osgeo.org
>>> Where are you getting that value of the variable smgMap ?
>>> - Jackie
>>>> If I try to access a map via .net  fusion I always get this
>>> error...Code
>>>> works fine in regular viewer.   I have heard conflicting reports of
>>>> Fusion and .NET can someone please clarify?
>>>> MgUserInformation userInfo = new MgUserInformation(mgSessionId);
>>>>         MgSiteConnection siteConnection = new MgSiteConnection();
>>>>         siteConnection.Open(userInfo);
>>>>         MgResourceService resourceService =
>>>> siteConnection.CreateService(MgServiceType.ResourceService) as
>>>> MgResourceService;
>>>>         MgMap map = new MgMap();
>>>>         map.Open(resourceService, smgMap);
>>>> Resource was not found:
> Session:ba7530b4-ffff-ffff-800a-00142260e7d1_en_7F0000010AFC0AFB0AFA//So
>>>> leburyTwp.Map
>>>> Description: An unhandled exception occurred during the execution of
>>> the
>>>> current web request. Please review the stack trace for more
>>> information
>>>> about the error and where it originated in the code.
>>>> Exception Details: OSGeo.MapGuide.MgResourceNotFoundException:
>>> Resource
>>>> was not found:
>>>> leburyTwp.Map
>>>> Source Error:
>>>> Line 28:         MgResourceService resourceService =
>>>> MgResourceService;
>>>> Line 29:         MgMap map = new MgMap();
>>>> Line 30:         map.Open(resourceService, smgMap);
>>>> Brian Berdel
>>>> p: 215.283.9444
>>>> www.mcmtrans.com
>>>> Brian Berdel
>>>> Applications Development Manager
>>>> 425 Commerce Drive, Suite 200
>>>> Fort Washington, Pennsylvania 19034
>>>> p: 215.283.9444
>>>> f:  215.283.9858
>>>> brian.berdel at mcmtrans.com
>>>>   <http://www.mcmtrans.com>
>>>>    New England  |  Mid-Atlantic  |  Florida
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> View this message in context:
>>> http://www.nabble.com/.NET-Fusion-tp16722611s16610p16736574.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> http://themapguyde.blogspot.com
>> http://www.linkedin.com/in/jackieng
