[mapguide-users] MGOS v2.0 join with other feature source issue
Jackie C. Ng jumpinjackie at gmail.com
Fri Apr 25 01:18:40 EDT 2008
With the second table, are you trying to join with the primary (one with
polygons) or the secondary (the access database) feature class?
- Jackie
David Nuell wrote:
> Hi all -
> I have MGOS v2.0 installed on a Win box with server 2003 installed.  I am
> also using Autodesk MapGuide Studio v 1.2.0.410 to build the web page.
> I have connected my MS Access DB through OSGeo FDO Provider for ODBC and
> am attempting to join the tables within that DB with my data layer.
> I am successful in connecting a single table to my data and it displays
> perfectly fine with the joined attributes.  When I attempt to connect a
> second table to the same data, the join works perfectly fine, however the
> data (polygons) do not display anymore.  When I remove the second table
> and refresh, it displays just fine again.
> I have tried different tables, and in different orders however it seems
> that only a single table can be joined and be displayed.  Has anyone else
> run into this?  Is there a maximum number of joins allowed?
> cheers.
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/MGOS-v2.0-join-with-other-feature-source-issue-tp16834759p16890704.html
