[mapguide-users] OnSelectionChanged in AJAX viewer?
Ivan Milicevic Ivan.Milicevic at supranet.hr
Mon Apr 28 05:03:59 EDT 2008
Feature doesn't get highlighted?
Of course that you can add this functionality  in your own code, the
logic is same. Allwas call mapFrame functions (via JavaScript) or count
selection from C# or PHP.
If you want to get some help over here, be more specific.
Ivan.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Tanja
Suikkanen
Sent: Monday, April 28, 2008 10:46 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] OnSelectionChanged in AJAX viewer?
Ok, now it worked but some functionality had been removed?
When I first select a feature, everything goes fine but when I select
another feature, that doesn't get highlighted...
Also I wouldn't like to change the original files, just add my own
functionality in my own code files.
But thanks anyway!
Tanja
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080428/b3498551/attachment.html
