[mapguide-users] OnSelectionChanged in AJAX viewer?
Kimmo Kotajärvi Kimmo.Kotajarvi at vianova.fi
Mon Apr 28 07:30:31 EDT 2008
Here's my solution (simplified):
<!-- Javascript part -->
<script type="text/javascript">
    var mapFrame = null;   // A reference to the map frame
    var originalMapFrameOnSelectionChanged = null // storage for the original onSelectionChanged function
    function OnSelectionChanged() // when something is selected on the map
        alert('Your handler works perfectly');
        originalMapFrameOnSelectionChanged();
    function InitDocument()
        mapFrameRef = frames[0].frames[1];
originalMapFrameOnSelectionChanged = mapFrameRef.parent.OnSelectionChanged;
        mapFrameRef.parent.OnSelectionChanged = OnSelectionChanged;
</script>
<!-- HTML part -->
<html>
<body onload="javascript:InitDocument()">
        <iframe id="viewerFrame" frameborder="yes" width="100%" height="60%" src=" src="../mapviewernet/dwfviewer.aspx?SESSION=<%=sessionId%>&WEBLAYOUT=<%=webLayout%>""></iframe>
</body>
</html>
So, body onload calls InitDocument which registers the new OnSelectionChanged event handler. The new handler only pops up a dialog box and then calls the old function. The MG Viewer is embedded in an iframe.
Lähettäjä: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] Puolesta Tanja Suikkanen
Lähetetty: 28. huhtikuuta 2008 14:10
Vastaanottaja: mapguide-users at lists.osgeo.org
Aihe: Re: [mapguide-users] OnSelectionChanged in AJAX viewer?
My map is embedded in my own page.
When a user selects one or more features on the map, I want my own function to be executed.
But doesn't parent.parent.mapFrame still get me the map frame..?
And this works but only when I click some button.
Tanja
From: Kenneth, GEOGRAF A/S [mailto:ks at geograf.dk]
Sent: 28. huhtikuuta 2008 13:57
To: tanja.suikkanen at dimenteq.fi; MapGuide Users Mail List
Subject: SPAM-LOW: Re: [mapguide-users] OnSelectionChanged in AJAX viewer?
Are you issuing the script from a command?
If you want to do this all the time (regardless of what the user has done), you must load the script with the solution.
If your map is embedded in another page, you can load the script there, and change "var map = parent.parent.mapFrame;" to point to the correct frame.
If it is just the basic layout, you can try to put it in the page that loads in the taskpane (but beware that the document gets unloaded if the user navigates).
As a last resort, you can embed the script in the viewerfiles.
In case you can use the embedded map approach, you should place the following line after the "try {":
map = document.getElementById('<insert iframe/frame id>').GetMapFrame()
Regards, Kenneth, GEOGRAF A/S
Tanja Suikkanen skrev:
Ok, I sent my code snippet earlier today, but here it is again.
I got this example from http://trac.osgeo.org/mapguide/wiki/CodeSamples/JavaScript/AJAXViewerEventHooking.
    var origOnSelectionChanged = null;
    function MySelectionHandler()
        origOnSelectionChanged();
        var selCount = map.GetSelectedCount();
        if(selCount > 0)
            My function() {}
    window.onload = function() {
        var timer;
        var watch = function() {
            try {
                if(map.mapInit) {
                    clearInterval(timer);
                    origOnSelectionChanged = map.OnSelectionChanged;
                    map.OnSelectionChanged = MySelectionHandler;
            catch(e) {
        timer = setInterval(watch, 200);
Window.onload function is executed only, if I press a button.
I want to have the functionality I was telling you about without any button clicks.
Please ask if I don't tell you enough.
Tanja
From: Ivan Milicevic [mailto:Ivan.Milicevic at supranet.hr]
Sent: 28. huhtikuuta 2008 12:04
Subject: RE: [mapguide-users] OnSelectionChanged in AJAX viewer?
Feature doesn't get highlighted?
Of course that you can add this functionality  in your own code, the logic is same. Allwas call mapFrame functions (via JavaScript) or count selection from C# or PHP.
If you want to get some help over here, be more specific.
Ivan.
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Tanja Suikkanen
Sent: Monday, April 28, 2008 10:46 AM
To: mapguide-users at lists.osgeo.org
Ok, now it worked but some functionality had been removed?
When I first select a feature, everything goes fine but when I select another feature, that doesn't get highlighted...
Also I wouldn't like to change the original files, just add my own functionality in my own code files.
But thanks anyway!
Tanja
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080428/f0728012/attachment.html
