[mapguide-users] OnSelectionChanged in AJAX viewer?
Kenneth, GEOGRAF A/S ks at geograf.dk
Mon Apr 28 09:00:44 EDT 2008
I made a small mistake.
The retry condition should not be:
if (mapFrame == null)
            window.setTimeout("RetryInit();", 500);
but
if (originalMapFrameOnSelectionChanged == null)
    mapFrame = null;
Because the frame may exist, but the function might be missing.
Regards, Kenneth, GEOGRAF A/S
Kenneth, GEOGRAF A/S skrev:
> You must safeguard against timing problems.
> It is very likely that your frame will load completely before the
> iframe does.
> In that case, you cannot get the OnSelectionChanged method reference.
> You can add an "onload" to the iframe, but it is still possible that
> it will break, because the internal frames do not load in the expected
> order.
> A simple fix is to wrap your "InitDocument" with a timer.
> Also, using the "frames[0].frames[1]" is relying on the order of your
> page, and the order of the viewer frames.
> A more reliable method, is to use the ID if the frame element, and
> then use the built-in method GetMapFrame().
> I have applied the above to your example:
> <!-- Javascript part -->
> <script type="text/javascript">
>     var mapFrame = null;   // A reference to the map frame
>     var originalMapFrameOnSelectionChanged = null // storage for the
> original onSelectionChanged function
>     function OnSelectionChanged() // when something is selected on the map
>         alert('Your handler works perfectly');
>         originalMapFrameOnSelectionChanged();
>     function InitDocument()
>         var win = document.getElementById('viewerFrame');
>         if (win.contentWindow) //FF returns the actual tag, IE returns
> the iframe
>           win = win.contentWindow;
>         mapFrameRef = win.GetMapFrame();
> mapFrameRef.parent.OnSelectionChanged;
>         mapFrameRef.parent.OnSelectionChanged =
> OnSelectionChanged;
>     function RetryInit()
>         if (mapFrame != null)
>             return;
>         try
>             InitDocument();
>         catch (e)
>             mapFrame = null;
> </script>
> <!-- HTML part -->
> <html>
> <body>
>     <iframe id="viewerFrame" frameborder="yes" width="100%"
> height="60%" src="
> src="../mapviewernet/dwfviewer.aspx?SESSION=<%=sessionId%>&WEBLAYOUT=<%=webLayout%>""
> onload="RetryInit()"></iframe>
> </body>
> </html>
> Kimmo Kotajärvi skrev:
>> Here's my solution (simplified):
>> the map
>>         mapFrameRef = frames[0].frames[1];
>> OnSelectionChanged;
>> </script>
>> <!-- HTML part -->
>> <html>
>> <body onload="javascript:InitDocument()">
>> height="60%" src="
>> src="../mapviewernet/dwfviewer.aspx?SESSION=<%=sessionId%>&WEBLAYOUT=<%=webLayout%>""></iframe>
>> </body>
>> </html>
>> So, body onload calls InitDocument which registers the new
>> OnSelectionChanged event handler. The new handler only pops up a
>> dialog box and then calls the old function. The MG Viewer is embedded
>> in an iframe.
>> *Lähettäjä:* mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] *Puolesta *Tanja
>> Suikkanen
>> *Lähetetty:* 28. huhtikuuta 2008 14:10
>> *Vastaanottaja:* mapguide-users at lists.osgeo.org
>> *Aihe:* Re: [mapguide-users] OnSelectionChanged in AJAX viewer?
>> My map is embedded in my own page.
>> When a user selects one or more features on the map, I want my own
>> function to be executed.
>> But doesn't parent.parent.mapFrame still get me the map frame..?
>> And this works but only when I click some button.
>> Tanja
>> *From:* Kenneth, GEOGRAF A/S [mailto:ks at geograf.dk]
>> *Sent:* 28. huhtikuuta 2008 13:57
>> *To:* tanja.suikkanen at dimenteq.fi; MapGuide Users Mail List
>> *Subject:* SPAM-LOW: Re: [mapguide-users] OnSelectionChanged in AJAX
>> viewer?
>> Are you issuing the script from a command?
>> If you want to do this all the time (regardless of what the user has
>> done), you must load the script with the solution.
>> If your map is embedded in another page, you can load the script
>> there, and change "var map = parent.parent.mapFrame;" to point to the
>> correct frame.
>> If it is just the basic layout, you can try to put it in the page
>> that loads in the taskpane (but beware that the document gets
>> unloaded if the user navigates).
>> As a last resort, you can embed the script in the viewerfiles.
>> In case you can use the embedded map approach, you should place the
>> following line after the "try {":
>> map = document.getElementById('<insert iframe/frame id>').GetMapFrame()
>> Tanja Suikkanen skrev:
>> Ok, I sent my code snippet earlier today, but here it is again.
>> I got this example from
>> http://trac.osgeo.org/mapguide/wiki/CodeSamples/JavaScript/AJAXViewerEventHooking.
>>     var origOnSelectionChanged = null;
>>     function MySelectionHandler()
>>         origOnSelectionChanged();
>>         var selCount = map.GetSelectedCount();
>>         if(selCount > 0)
>>             My function() {}
>>     window.onload = function() {
>>         var timer;
>>         var watch = function() {
>>             try {
>>                 if(map.mapInit) {
>>                     clearInterval(timer);
>>                     origOnSelectionChanged = map.OnSelectionChanged;
>>                     map.OnSelectionChanged = MySelectionHandler;
>>             catch(e) {
>>         timer = setInterval(watch, 200);
>> Window.onload function is executed only, if I press a button.
>> I want to have the functionality I was telling you about without any
>> button clicks.
>> Please ask if I don't tell you enough.
>> Tanja
>> *From:* Ivan Milicevic [mailto:Ivan.Milicevic at supranet.hr]
>> *Sent:* 28. huhtikuuta 2008 12:04
>> <mailto:tanja.suikkanen at dimenteq.fi>; MapGuide Users Mail List
>> *Subject:* RE: [mapguide-users] OnSelectionChanged in AJAX viewer?
>> Feature doesn't get highlighted?
>> Of course that you can add this functionality  in your own code, the
>> logic is same. Allwas call mapFrame functions (via JavaScript) or
>> count selection from C# or PHP.
>> If you want to get some help over here, be more specific.
>> Ivan.
>> *From:* mapguide-users-bounces at lists.osgeo.org
>> <mailto:mapguide-users-bounces at lists.osgeo.org>
>> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Tanja
>> Suikkanen
>> *Sent:* Monday, April 28, 2008 10:46 AM
>> *To:* mapguide-users at lists.osgeo.org
>> <mailto:mapguide-users at lists.osgeo.org>
>> Ok, now it worked but some functionality had been removed?
>> When I first select a feature, everything goes fine but when I select
>> another feature, that doesn't get highlighted...
>> Also I wouldn't like to change the original files, just add my own
>> functionality in my own code files.
>> But thanks anyway!
>> Tanja
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080428/583c7544/attachment.html
