[mapguide-users] MGOS v2.0 join with other feature source issue
Jason Birch Jason.Birch at nanaimo.ca
Mon Apr 28 16:01:42 EDT 2008
I'm not sure that you're going to find many people that have run into
this situation.
Personally, I don't use MapGuide joins at all if I can help it; they are
far less efficient than reading the data from a single source or relying
on the data source's native join capabilities.
I would suggest that you create a Trac ticket for this (if you haven't
already) regardless of whether you get a response.  Please provide
step-by-step instructions, and if at all possible data, that will allow
the developers to quickly see the problem.
http://trac.osgeo.org/mapguide/wiki/SubmitTicket
Jason
-----Original Message-----
Subject: Re: [mapguide-users] MGOS v2.0 join with other feature source
issue
When I attempt to join the first table in the DB to my data resource, I
can
see the joined attributes and polygons in the layers resource.  No issue
there.
when I attempt to join a SECOND table from the DB to my data resource, I
can
see the joined attributes from the first and second tables, however I
can
not see the polygons when I refresh the layer resource.
