[mapguide-users] MGOS v2.0 join with other feature source issue
David Nuell nuell at nicholsenvironmental.com
Tue Apr 29 18:47:53 EDT 2008
Never thought of that.  I went back into Access and created and saved my
query.  Re-loaded the DB into Mapguide Studio and joined my features with
the DB query.  Works like a charm.  I appreciate the idea.
Dave Wilson-3 wrote:
> As a workaround why not create a query in your Access database that will
> behave as a View in MGE?
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: Monday, April 28, 2008 2:02 PM
> To: MapGuide Users Mail List
> Subject: RE: [mapguide-users] MGOS v2.0 join with other feature source
> issue
> I'm not sure that you're going to find many people that have run into
> this situation.
> Personally, I don't use MapGuide joins at all if I can help it; they are
> far less efficient than reading the data from a single source or relying
> on the data source's native join capabilities.
> I would suggest that you create a Trac ticket for this (if you haven't
> already) regardless of whether you get a response.  Please provide
> step-by-step instructions, and if at all possible data, that will allow
> the developers to quickly see the problem.
> http://trac.osgeo.org/mapguide/wiki/SubmitTicket
> Jason
> From: David Nuell
> Subject: Re: [mapguide-users] MGOS v2.0 join with other feature source
> issue
> When I attempt to join the first table in the DB to my data resource, I
> can
> see the joined attributes and polygons in the layers resource.  No issue
> there.
> when I attempt to join a SECOND table from the DB to my data resource, I
> can
> see the joined attributes from the first and second tables, however I
> can
> not see the polygons when I refresh the layer resource.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/MGOS-v2.0-join-with-other-feature-source-issue-tp16834759p16972191.html
