[mapguide-users] MG2.0 install with other web applications
Xetec xetec at hotmail.com
Wed Apr 30 12:08:27 EDT 2008
I'm looking to find out how to install MapGuide 2.0 server along with other
web applications that are installed in the "Default Website" location in the
IIS manager?  We've run into a challenge with the server not running
correctly along side web applications that use .NET1.1.  The problem exists
after everything is installed.  I can log into the admin page and the web
studio page, but when I try to connect to the server via MapGuide Studio
2009 beta or AutoCAD Map, I get a connection error.  When I change the
ASPNET tab to run .NET 2.0 for the mapguide server it makes all the other
.NET 1.1 sites lock up and shows an error message in IIS of not being able
to run both 1.1 and 2.0 applications in one location.  Maybe there is a way
to do this correctly, but I was hoping to find out if Mapguide server could
be installed outside of the "Default Website" location on IIS. Or if there
is a way to configure this to work properly.
Additionally, we have been able to run MG2.0 successfully on our test
server, but it has no applications other than the Mapguide server are
installed.  So the problem exists with installation on our web application
server since there are other .NET 1.1 applications are running on the
server.
Any ideas or suggestions would be appreciated.  Thanks.
-Bob
View this message in context: http://www.nabble.com/MG2.0-install-with-other-web-applications-tp16986233p16986233.html
