[mapguide-users] Import Views from Oracle Spatial
Dragan Podvezanec dragan.podvezanec at gmail.com
Fri Aug 1 03:07:33 EDT 2008
A. Fischer wrote:
> I tried all. First I used SqlSheet for giving the views a primary key
> and/or
> a spatial index but both is not allowed to a View.
> Also I downloaded fdo2fdo but I didn't get a connection to my database
> with
> this although it works with MapGuide Maestro and I used the same settings.
> But fdo2fdo gives the error "ORA-12154: TNS: could not resolve the connect
> identifier specified"
It seems like you don't have Oracle Instant client installed: you can get it
here:
www.oracle.com/technology/tech/oci/instantclient/instantclient.html
After installing it, edit NETOWRK/ADMIN/tnsnames.ora file which will be in
Oracle installation directory, with something  like this:
MYSERVER =
  (DESCRIPTION = MYSERVER
    (ADDRESS_LIST =
      (ADDRESS = (PROTOCOL = TCP)(HOST = localhost)(PORT = 1521))
    (CONNECT_DATA =
      (SID = orcl)
      (SERVER = DEDICATED)
After editing, try
tnsping MYSERVER
from command line. If it works, you'll be able to use king.oracle.
View this message in context: http://www.nabble.com/Import-Views-from-Oracle-Spatial-tp18689745p18769269.html
