[mapguide-users] Compound line with Cartographic Stylization Engine
Tom Fukushima tom.fukushima at autodesk.com
Fri Aug 1 13:01:09 EDT 2008
In the release notes for 2.0.1 (http://trac.osgeo.org/mapguide/wiki/Release/2.0/Notes) there is a note in the API section about a change.  Perhaps that is the source of the schema validation error.
Also, did you start with a symbol definition and modify it?  If so, perhaps we should update that source symbol definition if it is public.
Tom
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of J Manafi
Sent: Thursday, July 31, 2008 3:06 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Compound line with Cartographic Stylization Engine
I am having some issues when trying to create composite features, and I was
hoping someone could point out what I am doing wrong. I just constructed a
new SymbolDefinition, and was trying to test it out by drawing it on the
map. However, currently, I am getting an XML Schema validation error saying
that the xml document is not valid.  I am not quite sure if I read the
LayerDefinition and SymbolDefinition .xsd files correctly, so that is quite
possibly where my error lies. I have included my 2 files.
I have already retrieved and verified that the SymbolDefinition is in the
repository, at the location I am looking. And this is for a dynamically
generated layer, so the resource Id is passed in later.
Any help is appreciated.
Thanks.
LayerDefinition file:
<LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="LayerDefinition-1.1.0.xsd" version="1.1.0">
 <VectorLayerDefinition>
  <ResourceId>%s</ResourceId>
  <FeatureName>polyline_Schema:tmp_polyline</FeatureName>
  <FeatureNameType>FeatureClass</FeatureNameType>
  <PropertyMapping>
   <Name>NAME</Name>
   <Value>NAME</Value>
  </PropertyMapping>
  <Geometry>GEOM</Geometry>
  <VectorScaleRange>
   <MaxScale>12000000</MaxScale>
   <CompositeTypeStyle>
       <CompositeRule>
           <LegendLabel>Test</LegendLabel>
           <CompositeSymbolization>
             <SymbolInstance>
<ResourceId>Library://Path/To/File.SymbolDefinition</ResourceId>
               <ParameterOverrides>
                 <Override>
                   <SymbolName>Fault</SymbolName>
                   <ParameterIdentifier>LINE_WEIGHT</ParameterIdentifier>
                   <ParameterValue>1.0</ParameterValue>
                 </Override>
               </ParameterOverrides>
             </SymbolInstance>
       </CompositeRule>
   </CompositeTypeStyle>
  </VectorScaleRange>
 </VectorLayerDefinition>
</LayerDefinition>
SymbolDefinition file:
<SimpleSymbolDefinition>
  <Name>Fault</Name>
  <Description>Fault</Description>
  <Graphics>
    <Path>
      <Geometry>
        M 0.0, 0.0 L 5.0, 0.0
        M 2.5, 0.0 L 2.5, 3.0
      </Geometry>
      <LineWeight>%LINE_WEIGHT%</LineWeight>
      <LineCap>'Square'</LineCap>
      <LineJoin>'Round'</LineJoin>
    </Path>
  </Graphics>
  <LineUsage>
    <VertexControl>'OverlapWrap'</VertexControl>
    <Repeat>5</Repeat>
  </LineUsage>
  <ParameterDefinition>
    <Parameter>
      <Identifier>LINE_WEIGHT</Identifier>
      <DefaultValue>1.0</DefaultValue>
      <DisplayName>Line Weight</DisplayName>
      <DataType>Real</DataType>
    </Parameter>
  </ParameterDefinition>
</SimpleSymbolDefinition>
