[mapguide-users] Finding the data file path i.e. the value of "%MG_DATA_FILE_PATH%"
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Aug 7 02:45:26 EDT 2008
I have not found a way to get it.
I have seen others asking for it, but with no replies.
If you want a copy of the files, you can get them with the
"GetResourceData" call.
You can write them back with "SetResourceData".
This might not be viable if you are planning on reading/writing large
SDF files though.
Regards, Kenneth Skovhede, GEOGRAF A/S
Carl Jokl skrev:
> I am writing some code whereby data manipulation of features is happening
> through FDO rather than mapguide. The problem I have is that when it comes
> to working with any auto generated temporary feature sources the file will
> be stored in the location defined by %MG_DATA_FILE_PATH%. What I would like
> to do is get hold of the value of the data file path from the MapGuide API
> in order to be able to replace this constant with it's value. Is this
> possible and if so how would I go about it?
