[mapguide-users] trouble replicating interstate symbol definition
Jonathan Manafi jonathan.manafi at cctechnol.com
Thu Aug 7 13:20:27 EDT 2008
Hmm...I just tried that as well, and the process worked, in that it
created a symbol with that information. However, when I tried using it
on the map, it again displayed nothing for me.
One other question Martin: When I tried uploading the xml to the server,
I got an error message with an exception thrown with a validation error
message. I had received that in Studio as well, because
<SimplSymbolDefinition> needs a 'version=1.0.0' attribute. So, I
included that, but I still got an error. It wasn't until I had declared
at the top of the file
    <SimpleSymbolDefinition
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xsi:noNamespaceSchemaLocation="SymbolDefinition-1.0.0.xsd"
    version="1.0.0">
that I got it load to the server. Did you never have to go through this
in order to save your files?
Thanks.
The exact error message was
    An exception occurred in the XML parser.
An exception occurred in the XML parser. Exception occurred in method
MgResourceContentManager.ValidateDocument at line 556 in file
c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ResourceContentManager.cpp
Martin Morrison wrote:
> I created the symbols outside of Studio using a text editor and then
> loaded them into the server.  I will say that the first attempt or two
> at using online encoders to base64 didn't work the file was radically
> different that what was shown below.  I did hit on one that worked
> well, I have it bookmarked but I don't have access to that bookmark
> right now.  You can look at the symbols created by the xml below by
> going to http://gis.edsi/com then follow the links to the Mecklenburg
> County public site.
> Thanks,
> Martin
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080807/66b4a590/attachment.html
