[mapguide-users] query in sheboygan is not working
Andy Morsell amorsell at spatialgis.com
Thu Aug 7 19:51:26 EDT 2008
Along the lines of the online demo sites running version 1.2, I keep
accessing them for one reason or another and then wonder why they're not
working.  Then I realize that I'm running Firefox 3 and that the sites must
still be pre-2.0 so then I switch to IE.  That might be another compelling
reason to get things upgraded.
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Tom Fukushima
Sent: Thursday, August 07, 2008 4:41 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] query in sheboygan is not working
The online version is running 1.2 and there were some breaking API changes
with the coordinate system API in 2.0 (see
http://trac.osgeo.org/mapguide/wiki/Release/2.0/Notes) so that's why the
online version works, but yours doesn't.  You will probably need to change
the PHP scripts so that "new MgCoordinateSystemTransform" is not used.
BTW, to help you debug these PHP pages, you should turn the PHP error
logging on in the php.ini file found in the WebServerExtensions/Php
directory.  Search for the line that starts with display_errors (not "; -
display_errors" because that's a comment line) and change it to
display_errors = on.  You may have to restart your web server.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of oamram
Sent: Thursday, August 07, 2008 5:12 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] query in sheboygan is not working
Hi All,
new to this, i installed mapguide 2 and it works great.
however the query function does not work at all.
any suggestion on how to solve it?
i also download the redding package and the query does not work, how on the
online version of the
of the redding application the query function does work.
much appriciated , Omer.
View this message in context:
http://www.nabble.com/query-in-sheboygan-is-not-working-tp18881736p18881736.
html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
