[mapguide-users] Query String Auto-Login with Fusion or Flexible Layouts
Rock Beans rockbeans at gmail.com
Fri Aug 8 16:19:22 EDT 2008
Can you send me the links to this concept? I am trying to help a basic user
that does not want to get to deep but if it is easy to implement why not.
On Thu, Aug 7, 2008 at 2:18 PM, Andy Morsell <amorsell at spatialgis.com>wrote:
>  No, that does not work with Fusion.  There were some threads on this a
> couple of months ago that might be worth perusing.  The short of it is
> that if you call a Fusion appDef from the file system, it uses the hardcoded
> Anonymous user so there will be no prompting, etc.  So, no need to API
> create a &Session.  However, if you are calling the appDef from the
> repository, then MGOS does it own authentication in which case you would
> need to pass the session as credentials.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> www.SpatialGIS.com
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Rock Beans
> *Sent:* Thursday, August 07, 2008 11:53 AM
> *To:* MapGuide Users Mail List
> *Subject:* [mapguide-users] Query String Auto-Login with Fusion or
> Flexible Layouts
> Using the old standard AJAX viewer you could add
> &USERNAME=Anonymous&PASSWORD= to the URL allowing no login box to pop up.
> Can this be done with the new Fusion based viewer without having to API
> create a &Session?
> The Rock
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080808/02804c43/attachment.html
