[mapguide-users] too Many Connections error(JSP+MySQL)
=?GB2312?B?0OzV8A==?= xuzhengeology at gmail.com
Mon Aug 11 02:54:05 EDT 2008
Thank u veymuch for your useful help.
It did work well now.Thank u again.: )
I rechecked my codes to see whether i have other mistakes.
I find that featureReader.close() is used for the close of select operation.
For featService.UpdateFeatures operation,we should set the 3rd parameter to
false like this:
featService.UpdateFeatures(resId, commands, false);
so the connections created by Update operation can be released.
Jacky.
2008/8/6, Zac Spitzer <zac.spitzer at gmail.com>:
> try using featureReader close()
> z
> On Wed, Aug 6, 2008 at 7:30 PM, ÐìÕð <xuzhengeology at gmail.com> wrote:
> > Hi,
> >     I use JSP and MySQL to develop .FDO connects these two parts
> together.
> >     In the software,i use resource service and feature service to search
> > data stored in the MySQL database.Once i run the page for searching.
> > I will got two sleep process in MySQL.I guess the reason is i forgot to
> > close connections.So i go back to the code to close connections and
> > services.No use.
> > Codes here:
> > public Vector select(String mapName,String layerName,String
> > layerClassName,String filterString)  throws MgException
> >   MgResourceService resService =
> (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
> >   MgFeatureService featService =
> (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
> >   MgMap map = new MgMap();
> >   map.Open(resService, mapName);
> >   MgLayer layer = getLayerByName(map, layerName);
> >   MgFeatureQueryOptions query = new MgFeatureQueryOptions();
> >   query.SetFilter(filterString);
> >    MgResourceIdentifier resId = new
> > MgResourceIdentifier(layer.GetFeatureSourceId());
> >   MgFeatureReader featureReader =featService.SelectFeatures(resId,
> > layerClassName, query);
> >   Vector vec=new Vector();
> >    while (featureReader.ReadNext())
> >    MgAgfReaderWriter geometryReaderWriter = new MgAgfReaderWriter();
> >    String mc = featureReader.GetString("MC");
> >    long id=featureReader.GetInt64("FeatId");
> >    long id1=featureReader.GetInt64("id");
> >    MgByteReader byteReader = featureReader.GetGeometry("GEOMETRY");
> >    MgGeometry geometry = geometryReaderWriter.Read(byteReader);
> >    MgPoint point = geometry.GetCentroid();
> >    double x = point.GetCoordinate().GetX();
> >    double y = point.GetCoordinate().GetY();
> >    xy n=new  xy(x,y,id,id1,mc);
> >    vec.add(n);
> >    geometryReaderWriter.delete();        //close
> >   resService.delete();                          //close
> >   featService.delete();                         //close
> >   map.delete();                                  //close
> >   return vec;
> > out of this function,i closed the connection to the site with
> > "siteConnection.delete();"
> > Once i run this function ,checking the process of MySQL with "show
> > processlist" in MySQL command shell,i will got two more sleep
> process,which
> > can not be closed.
> > original:
> > mysql> show processlist;
> > | Id    | User | Host                | db          | Command | Time |
> State
> > | Info
> > |   1   | root  | localhost:4955  | psd        | Sleep        |    2
> >  |           | NULL
> > | 193 | root   | localhost:3941 | NULL      | Query       |    0   |
> NULL  |
> > show processlist |
> > | 194 | root   | localhost:3963 | jsof_data | Sleep        |
> > 4   |           | NULL
> > | 195 | root   | localhost:3964 | jsof_data | Sleep        |    8
> > |            | NULL
> > 2 rows in set (0.00 sec)
> > ofter used the function:
> State
> > | Info
> >  |           | NULL
> NULL  |
> > show processlist |
> > 4   |           | NULL
> > |            | NULL
> > | 196 | root   | localhost:3965 | jsof_data | Sleep
> >  |    2   |           | NULL
> > | 197 | root   | localhost:3966 | jsof_data | Sleep        |    3
> > |            | NULL
> > 6 rows in set (0.00 sec)
> > i tried to kill the sleep process with the ways as follow:
> > <%@ page language="java" import="java.util.*" pageEncoding="gb2312"%>
> > <%@ page import="java.sql.*"%>
> > <%@ page import="java.util.*"%>
> > <%@ page import="java.io.*"%>
> >      String path = request.getContextPath();
> >      String basePath = request.getScheme() + "://"
> >                                 + request.getServerName() + ":" +
> > request.getServerPort()
> >                                 + path + "/";
> >      Class.forName("com.mysql.jdbc.Driver");
> >      String url =
> "jdbc:mysql://localhost/psd?characterEncoding=utf8&user=root&password=root";
> >      Connection conn = DriverManager.getConnection(url);
> >      Statement stmt = conn.createStatement();
> >      Statement stmt2 = conn.createStatement();
> >      ResultSet rs = stmt.executeQuery("show processlist");
> >      while (rs.next()) {
> >          String Id = rs.getString("Id");
> >             String cmd = rs.getString("Command");
> >             String Time = rs.getString("Time");
> >             int i = Integer.parseInt(Time);
> >             if(i>10&&cmd.equals("Sleep"))                        //Kill
> the
> > process which has been slept for more than 10 seconds
> >                stmt2.executeQuery("kill "+Id);
> >             else
> >      rs.close();
> >      stmt.close();
> >      stmt2.close();
> >      conn.close();
> > But i will get "The MySQL has gone away"error message.I have to restart
> > MapGuideServer service to fix this problem.
> > Can anyhelp me on this problem?
> > Thanks for your attention:)
> > Jacky.
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080811/e7ade266/attachment.html
