[mapguide-users] Tooltip on the marker
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Aug 12 01:19:49 EDT 2008
I assume you fill out the resourceID somehow.
Although it should work with just a string constant, have you tried with
a column name?
I'm not sure if tooltips work on data with no primary key, have you
tried it on data where there is a primary key?
If you try to load the layer manually, and open it in Studio or Maestro,
with a real data source, does that work then?
Regards, Kenneth Skovhede, GEOGRAF A/S
gracecwl skrev:
> Hi all,
> I try the method suggested, however, i cant get the desired output.
> May i know what happen. attached is my .xml file.
> http://www.nabble.com/file/p18937171/parcelmarker.xml parcelmarker.xml
> Farah-2 wrote:
>> Hi..!
>> It is possible to create tooltips for the pushpin markers. All u need to
>> do
>> is modify your layer xml file.
>> You need to add:
>> <ToolTip> Property Name</ToolTip>
>> In your layer.xml file.
>> Regards
>> Farah
>> -----Original Message-----
>> From: Kencana [mailto:bluesky_dyx at hotmail.com]
>> Sent: Monday, November 06, 2006 8:45 AM
>> To: users at mapguide.osgeo.org
>> Subject: [mapguide-users] Tooltip on the marker
>> hi all,
>> is that possible to create tooltip for the markers(push pin) just like
>> when
>> we add a tooltip features on a layer using mapguide studio?
>> I am looking forward for the reply and thank you for the guidance..
>> Regards,
>> Kencana
>> View this message in context:
>> http://www.nabble.com/Tooltip-on-the-marker-tf2580163.html#a7192696
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080812/ea8692d9/attachment.html
