[mapguide-users] Map or Layer Preview don't show the Geometry
Alexander Fischer deejot at gmx.de
Tue Aug 12 05:25:42 EDT 2008
The Oracle SRID or rather the EPSG-Code is 24878.
Now I saw, that the WKTEXT which is shown in webstudio is a little bit
different to the WKTEXT in the MDSYS.CS_SRS - Table.
Could this be the problem? But what can I do for this?
Kind regards,
Alexander Fischer
2008/8/12 Simon Pelicon <simon at sl-king.com>
>  Hi,
> What is Oracle SRID for this geometry?
> Simon
> Alexander Fischer wrote:
> Hi,
> I'm working with MapGuide Open Source (2.0.1), MapGuide Maestro and
> King.Oracle (0.7.4).
> The Dataconnection works and I created a map and a Layer where I attached a
> Geometry with polylines.
> Also I edited the Layer style and the initial map view but when I tried the
> Preview the browser showed only the mapviewer with an empty map (no
> geometry).
> When I open the data with the webstudio there is an advice in the
> Preview-window:
> "The coordinate system is invalid.
> Could not create coordinate system forward transformation with specified
> coordinate systems.
> Exception occurred in method MgCoordinateSystem.CCoordinateSystem at line
> 380 in file ..\CoordinateSystem\CoordSys.cpp"
> My used Coordinate system is PSAD56 / UTM zone 18S (EPSG:24878)
> So I checked the WKT Code with Web Tier Test:
> PROJCS["PSAD56 / UTM zone
> 18S",GEOGCS["PSAD56",DATUM["Provisional_South_American_Datum_1956",SPHEROID["International
> 1924",6378388,297,AUTHORITY["EPSG","7022"]],AUTHORITY["EPSG","6248"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4248"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-75],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",10000000],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","24878"]]
> Status: Pass
> I don't know where the problem could be. Has somebody an idea?
> I would be pleased to receive an answer.
> Kind regards, Alexander Fischer
> No virus found in this incoming message.
> Checked by AVG - http://www.avg.com
> Version: 8.0.138 / Virus Database: 270.6.0/1602 - Release Date: 9.8.2008 13:22
> mapguide-users mailing listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080812/8fca601e/attachment.html
