[mapguide-users] MGOS 2.0.1 Crash Issues
nclayton nclayton at gmail.com
Tue Aug 12 08:48:39 EDT 2008
We just upgraded our hardware and after a fresh install, I am now getting
mgserver.exe crashes with the errors below. Anyone have any idea on what
could be causing these?
Also, the server specs are:
Win2k3 Standard Server
2 Quad Core 2.33GHz CPUs
4GB RAM
In IIS6 I have created an application pool for MGOS and set up a web garden
with 8 worker processes.
The errors that I am getting are:
 Error: An unclassified exception occurred.
 StackTrace:
  - MgTimedEventHandler.handle_timeout line 123 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\core\TimedEventHandler.cpp
  - MgResourceChangeEventHandler.HandleEvent line 76 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\core\ResourceChangeEventHandler.cpp
  - MgServiceManager.DispatchResourceChangeNotifications line 530 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\common\manager\ServiceManager.cpp
  - MgServerResourceService.EnumerateParentMapDefinitions line 1108 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ServerResourceService.cpp
  - MgApplicationRepositoryManager.EnumerateParentMapDefinitions line 699
file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ApplicationRepositoryManager.cpp
  - MgApplicationResourceContentManager.EnumerateParentMapDefinitions line
214 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ApplicationResourceContentManager.cpp
 StackTrace:
  - MgRepositoryCheckpointEventHandler.HandleEvent line 79 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\core\RepositoryCheckpointEventHandler.cpp
  - MgServerResourceService.PerformCheckpoint line 2111 file
 StackTrace:
  - MgRenderingServiceHandler.ProcessOperation line 83 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
  - MgOpQueryFeatures.Execute line 125 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
  - MgServerRenderingService.QueryFeatures line 652 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\ServerRenderingService.cpp
 StackTrace:
  - MgOpRenderDynamicOverlay.Execute line 109 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\OpRenderDynamicOverlay.cpp
Several of these...
<2008-08-11T16:34:14> An unclassified exception occurred.
Got these for several layers of different types (raster, sdf)
Error: Failed to stylize layer: <layer name>
 StackTrace:
  - MgMappingUtil.StylizeLayers line 775 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\mapping\MappingUtil.cpp
        Cannot establish connection.
 StackTrace:
 Error: Invalid argument(s):
        The value cannot be less than or equal to zero.
 StackTrace:
  - MgServerRenderingService.RenderDynamicOverlay line 263 file
 Error: An exception occurred in FDO component.
        Memory allocation failed.
 StackTrace:
  - MgServerRenderingService.RenderForSelection line 1299 file
  - MgServerSelectFeatures.SelectFeatures line 249 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\feature\ServerSelectFeatures.cpp
 Error: Failed to stylize layer: <layer name (raster)>
 StackTrace:
Thank you all for your help!
View this message in context: http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18943673.html
