[mapguide-users] Create layer from oracle database without spatial data
Rahul unicorn_admirer at yahoo.com
Wed Aug 13 04:07:50 EDT 2008
Hey Buddy,
                       I think you can use oracle locator if u r allowed to as i belive its built in with Oracle 10g and no need to go with extra Spatial License and all,but if u r restricted to use non-spatial data ,i don't think its big problem to get point using the X,Y Values from the Table.
I think you check one more time as System DSN works perfectly and  the screen shot provided by you doesn't give  much idea so i unable to figure out for the same.
Max !
----- Original Message ----
To: mapguide-users at lists.osgeo.org
Sent: Tuesday, August 12, 2008 5:36:20 PM
Subject: Re: [mapguide-users] Create layer from oracle database without spatial data
Thanks for your information.
I would like to, but the power to make decisions is not on me, I was been
asked to do this.
BTW, I'm new with spatial data, is it take lots time to converting data to
oracle spatial?
or it's hard to maintain the server (data is continu upgrade)?
zspitzer wrote:
> is there any reason why your not just converting your data to oracle
> spatial?
> http://download.oracle.com/docs/cd/B19306_01/appdev.102/b14255/sdo_objrelschema.htm#CBBFGHAE
> On Tue, Aug 12, 2008 at 3:03 PM, 0uch <hwayuyu at yahoo.com.tw> wrote:
>> Hi Max,
>> Yes I have tried the way that you told before, and this is what I see
>> after
>> clicking "show table".
>> http://www.nabble.com/file/p18937853/mgs.jpg
>> I have no idea how to continue in this situation, so I have only one way
>> that use FDO provider for Oracle.
>> Are there any solution for this problem?
>> T.H. Yu.
>> max_samart wrote:
>>> Hi,
>>>      I think its not a big deal ,you can use MapGuide
>>>  Studio or Mastero for creating connection using the OsGeo
>>>  FDO Provider for ODBC and use DSN as oracle odbc driver
>>>  causes some error or you can also try King Oracle Provider
>>>  at www.sl-king.com in order to create the points using the
>>>  non spatial Table,once you establish the connection and all
>>>  you have to create layer using that connection and thn
>>>  select the X and Y column which will create points from your
>>>  oracle table.
>>>  I hope it will help you out to get started !
>>>  Max !
>>> From: 0uch <hwayuyu at yahoo.com.tw>
>>> Sent: Thursday, August 7, 2008 10:15:38 AM
>>> Subject: [mapguide-users] Create layer from oracle database without
>>> spatial data
>>> Hi all,
>>> Is that passable to create layer from an oracle database that without
>>> spatial data? (by studio 2009 or something else?)
>>> If not , are there any kind of way that could build my point data (ex:
>>> land-mark) on map?
>>> I'll be very appreciate with any useful information
>>> T.H. Yu.
>>> View this message in context:
>>> http://www.nabble.com/Create-layer-from-oracle-database-without-spatial-data-tp18848865p18848865.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> http://www.nabble.com/Create-layer-from-oracle-database-without-spatial-data-tp18848865p18937853.html
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
View this message in context: http://www.nabble.com/Create-layer-from-oracle-database-without-spatial-data-tp18848865p18941706.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080813/832d2617/attachment.html
