[mapguide-users] Create layer from oracle database without spatial data
0uch hwayuyu at yahoo.com.tw
Wed Aug 13 06:33:22 EDT 2008
I used mapguide studio and enterprise 2009 to create a landmark layer by
using oracle view data, it's work , but the landmark on map can not be
select.
Then I tried mapguide O.S. 2.0.1 with king.Oracle , it can create layer too,
but layer still can not be select.
The select properties was setting correctly.
Beside, the setting "Filter applied to data" in layer didn't work too,
whatever i set was useless.
Is there something wrong with my oracle data ? or some setting I missed?
Dragan Podvezanec wrote:
> If you use king.Oracle provider, you could use King.FDO.Class and then use
> table without spatial data: detailed procedure is described here:
> http://www.sl-king.com/fdooracle/KingFdoClass.htm
View this message in context: http://www.nabble.com/Create-layer-from-oracle-database-without-spatial-data-tp18848865p18960563.html
