[mapguide-users] Map or Layer Preview don't show the Geometry
Alexander Fischer deejot at gmx.de
Wed Aug 13 10:19:42 EDT 2008
Thank you all for your help!
I tried at first to override the coordinate system with an 'Arbitrary X-Y
Coordinates (Meter) (XY-M)'
but like Dennis said, it fails. In the preview I got the error that the
ressource was not found.
*Resource was not found:
Session:7731e412-0000-1000-8000-02004c4f4f50_en_7F0000010AFC0AFB0AFA//Samples/Nasca/Layers/ROAD.
LayerDefinition Exception occurred in method MgResourceDefinitionManager.
GetDocument at line 476 in file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
*Thanks too, Dennis for the sql-command. I will ask at first my professor
for this way of solution.
Kind regards,
Alexander Fischer
2008/8/13 Jonio, Dennis (Aviation) <DJonio at miami-airport.com>
>  Zac,
> My experience with the "override thingee" has not been positive. It is
> rather bizarre in my case … hit refresh and it pulls in the "correct" SRID
> from s-l king and shows the correct wkt!!! (same thing I get w/in Map3d by
> the way)  … anything I select for an override fails even arbXY … but then
> again, maybe I just don't understand …
> r,
> dennis
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kenneth Skovhede,
> GEOGRAF A/S
> *Sent:* Wednesday, August 13, 2008 6:53 AM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] Map or Layer Preview don't show the
> Geometry
> If the "Coordinate System Override" method that Zac mentions does not work,
> it seems like there will be better coordinate system support in the next
> MapGuide release:
> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc55
>  Regards, Kenneth Skovhede, GEOGRAF A/S
> Zac Spitzer skrev:
> did you try to override the feature source co-ordinates system?
> On Wed, Aug 13, 2008 at 8:25 PM, Jonio, Dennis (Aviation)
> <DJonio at miami-airport.com> <DJonio at miami-airport.com> wrote:
> Alex,
> Yes, it is known.
> Here is the sql 'knowledge' you need to transform your table. Just plug in
> the new SRID, in this case I transform to SRID = 8307. Also sdo_geometry
> column in this case is 'geometry'. Your 'time' issue I am not sure of but
> for me a transform of 200M records takes about 15 seconds.
> update YOUR_TABLE_NAME_HERE c set c.GEOMETRY = (select
> SDO_CS.TRANSFORM(c.GEOMETRY, m.diminfo, 8307) FROM user_sdo_geom_metadata m
> WHERE m.table_name = 'YOUR_TABLE_NAME_HERE');
> -- After completion make sure your user_sdo_geom_metadata entry for the
> table is correct.
> I wish I had a real solution for you. The way it was handed down to me is
> that MGOS does not like EPSG codes so it abends the methods. (it certainly
> does this well)
> IF the MGOS dev folks have addressed the issue their decision on resolution
> is unknown to me.
> r,
> dennis
> ________________________________
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org <mapguide-users-bounces at lists.osgeo.org>] On Behalf Of Alexander
> Fischer
> Sent: Wednesday, August 13, 2008 4:53 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Map or Layer Preview don't show the Geometry
> So, is this error known that some CoordinateSystems are not working with
> MGOS? Is there anywhere a list of these CoordinateSystems? I still hope that
> I made a mistake because I have neither the time nor the knowledge to
> transform the whole database into another WKT.
> Kind regards,
> Alex
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> E-mails are automatically scanned for viruses using McAfee.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080813/57f450ba/attachment.html
