[mapguide-users] Error creating Layer using MgResourceService::SetResource method
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Aug 13 13:06:09 EDT 2008
Can you post the Xml somewhere for verification?
I have seen a similar error once, when I managed to insert a broken xml
file as the header.
I fixed it by deleting the folder, and inserting the correct Xml.
Regards, Kenneth Skovhede, GEOGRAF A/S
wkhattak skrev:
> Hi,
> I am trying to create a layer using xml schema files
> (http://localhost/mapguide2009/mapagent/index.html --> SetResource).
> Although after clicking 'submit', the page doesn't display any error,
> however, upon viewing the layer's folder within MG Studio (or Maestro), the
> following error is thrown :
> "System.Exception: The remote server returned an error: (559)
> MgNullArgumentException.:
> Argument is null.
> Exception occurred in method MgXmlUtil.GetNodeList at line 331 in file
> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\common\foundation\System/XmlUtil.cpp"
> This results in a corrupted package.
> On the contrary, creating a feature source using the same functionality
> works fine. The layer is infact the one that I already created using MGE &
> then exported as XML.
> regards,
> W Khattak
