[mapguide-users] Re: Fusion using SVN as stated in Directions (JavaScript Error Fusion is Undefined)
Paul Spencer pagameba at gmail.com
Thu Aug 14 11:28:59 EDT 2008
The templates live in the mapguide svn so we can't really change them
until we up the revision of fusion in mapguide.  We are working on a
1.1 release of fusion for the end of summer/early fall that will
hopefully get incorporated into mapguide and provide a bunch of
performance enhancements, bug fixes and some new capabilities.  No
time to give details, too busy coding ... :)
Cheers
Paul
On 14-Aug-08, at 11:05 AM, Zac Spitzer wrote:
> you can always file a patch in trac
> On Fri, Aug 15, 2008 at 1:03 AM, Rock Beans <rockbeans at gmail.com>
> wrote:
>> Here it is
>> http://lists.osgeo.org/pipermail/mapguide-users/2008-July/
>> 013652.html will
>> this be commited to Fusion SVN soon as well as the other fixes?
>> Seems simple
>> enough. Give me access and I will do it :-)
>> The Rock
>> On Thu, Aug 14, 2008 at 9:14 AM, Rock Beans <rockbeans at gmail.com>
>> wrote:
>>> I followed the instructions on
>>> http://lists.osgeo.org/pipermail/mapguide-users/2008-July/013637.html
>>>  and I
>>> am not getting the viewer to come up anymore. Was there some major
>>> changes
>>> that would cause this or what id the fix? I assume I am missing
>>> some setting
>>> somewhere. Are there updated mapguide templates maybe since the
>>> default SVN
>>> copy only contains standard and you have to copy over the old. The
>>> checked
>>> out fusion directory is in the same location as before and the old
>>> files are
>>> in fusion_old just in case everything should be working right?
>>> The reason why I am even doing this is the Save Map function causes
>>> Javascript "Access Denied" errors. Is there any information on
>>> either of
>>> these topics please?
>>> Erro info: Error: OpenLayers.String.translate is not a function
>>> Source File:
>>> http://localhost/mapguide/fusion/templates/mapguide/slate/
>>> index.html...
>>> Line: 34
>>> Does this mean I need to add open layers or something or disable for
>>> MapGuide?
>>> The Rock
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
