[mapguide-users] Re: Fusion using SVN as stated in Directions (JavaScript Error Fusion is Undefined)
Rock Beans rockbeans at gmail.com
Thu Aug 14 12:00:53 EDT 2008
Any idea on the Save Map (SaveMap.php) issue I am seeing. I posted details
about this previously.
The Rock
On Thu, Aug 14, 2008 at 10:28 AM, Paul Spencer <pagameba at gmail.com> wrote:
> The templates live in the mapguide svn so we can't really change them until
> we up the revision of fusion in mapguide.  We are working on a 1.1 release
> of fusion for the end of summer/early fall that will hopefully get
> incorporated into mapguide and provide a bunch of performance enhancements,
> bug fixes and some new capabilities.  No time to give details, too busy
> coding ... :)
> Cheers
> Paul
> On 14-Aug-08, at 11:05 AM, Zac Spitzer wrote:
>  you can always file a patch in trac
>> On Fri, Aug 15, 2008 at 1:03 AM, Rock Beans <rockbeans at gmail.com> wrote:
>>> Here it is
>>> http://lists.osgeo.org/pipermail/mapguide-users/2008-July/013652.html
>>> will
>>> this be commited to Fusion SVN soon as well as the other fixes? Seems
>>> simple
>>> enough. Give me access and I will do it :-)
>>> The Rock
>>> On Thu, Aug 14, 2008 at 9:14 AM, Rock Beans <rockbeans at gmail.com> wrote:
>>>> I followed the instructions on
>>>> http://lists.osgeo.org/pipermail/mapguide-users/2008-July/013637.html and
>>>> I
>>>> am not getting the viewer to come up anymore. Was there some major
>>>> changes
>>>> that would cause this or what id the fix? I assume I am missing some
>>>> setting
>>>> somewhere. Are there updated mapguide templates maybe since the default
>>>> SVN
>>>> copy only contains standard and you have to copy over the old. The
>>>> checked
>>>> out fusion directory is in the same location as before and the old files
>>>> are
>>>> in fusion_old just in case everything should be working right?
>>>> The reason why I am even doing this is the Save Map function causes
>>>> Javascript "Access Denied" errors. Is there any information on either of
>>>> these topics please?
>>>> Erro info: Error: OpenLayers.String.translate is not a function
>>>> Source File:
>>>> http://localhost/mapguide/fusion/templates/mapguide/slate/index.html...
>>>> Line: 34
>>>> Does this mean I need to add open layers or something or disable for
>>>> MapGuide?
>>>> The Rock
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080814/b4872afd/attachment.html
