[mapguide-users] Fusion Save Map Issues
Jason Birch Jason.Birch at nanaimo.ca
Thu Aug 14 13:25:53 EDT 2008
It's quite possible (actually, I'm pretty sure) that the definition for
the SaveMap widget has changed considerably in Fusion trunk since 1.0.x,
so it's possible that neither Studio nor Maestro will generate these
correctly.
Also, the code in the SaveMap widget catches MapGuide exceptions, but
does not catch generic PHP exceptions.  You may get more information
from that code by adding a section like this after the MapGuide catch:
catch (Exception $e)
  echo "ERROR: " . $e->GetMessage() . "\n";
  exit;
Jason
Subject: Re: [mapguide-users] Fusion Save Map Issues
It may be an incompatibility in Studio that's the problem then - because
my xml certainly doesn't look anything like that. I'll give it a try in
Maestro a little later, and then if that doesn't work, I'll edit the xml
myself...
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080814/26617b72/attachment.html
