[mapguide-users] OGR provider for personal geodatabse
Techswami techswami at hotmail.com
Thu Aug 14 17:06:35 EDT 2008
none
it does not return any records
Techswami wrote:
> well you mean SN="-1" as SN is string i get the value -1
> but the feature reader  is empty
> featReader is empy no value there is i use SDE FDO i get value but not
> with OGR .
> tony
> zspitzer wrote:
>> how many records are being returned from the feature reader?
>> try setting  string SN = '-1' and see what comes out
>> On Thu, Aug 14, 2008 at 12:43 PM, Techswami <techswami at hotmail.com>
>> wrote:
>>> selection does not work.
>>> using the code bellow i dont get any value for variable "SN"
>>> please let me know what i am doing wrong . I am using OGR
>>> if ((layer != null) && (layer.GetName() == "main"))
>>>                        String layerClassName =
>>> layer.GetFeatureClassName();
>>>                        String selectString =
>>> l_oSel.GenerateFilter(layer,
>>> layerClassName);
>>>                        String layerFeatureIdString =
>>> layer.GetFeatureSourceId();
>>>                        MgResourceIdentifier layerResId = new
>>> MgResourceIdentifier(layerFeatureIdString);
>>>                        MgFeatureQueryOptions queryOptions = new
>>> MgFeatureQueryOptions();
>>>                        queryOptions.SetFilter(selectString);
>>>                        featReader =
>>> l_oFeatureSrvc.SelectFeatures(layerResId, layerClassName, queryOptions);
>>>                        string SN = null;
>>>                        while (featReader.ReadNext())
>>>                            SN = featReader.GetString("MATERIAL");
>>>                        Response.Write("<div id='box_content_header'>" +
>>> SN
>>> + "</div><br />");
>>>                        featReader.Close();
>>>                        featReader.Dispose();
>>> tony
>>> Techswami wrote:
>>>> hi
>>>> OGR provider works great for ESRI personal geodatabase(.mdbfile)  using
>>>> OGR but if I  select any feature then the entire layer can not be
>>>> viewed
>>>> in the map. i tried latest patch also . it does the same thing.
>>>> anyone has a same problem
>>>> please help
>>>> tony
>>> View this message in context:
>>> http://www.nabble.com/OGR-provider-for-personal-geodatabse-tp18948977p18974886.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
View this message in context: http://www.nabble.com/OGR-provider-for-personal-geodatabse-tp18948977p18989746.html
