[mapguide-users] too many ArcSDE 9.2 connections
Techswami techswami at hotmail.com
Fri Aug 15 01:54:26 EDT 2008
i am using arcsde 9.2 with MGE 2009 as well as MGOS 2.0
layer = 40
Database : SQL server 2005
here are the observations
1. with SDE 9.2 MGE makes so many connections that they use all the memory
and SDE server crashes
2. i went to esri and did increased the size still MGE is making  more
connection for no reason
     every zoom create connection to SDE
     identify does the same
3. I have connection pooling on so why does it do it
any one found the same issue
thanks
Tony
View this message in context: http://www.nabble.com/too-many-ArcSDE-9.2-connections-tp18994200p18994200.html
