[mapguide-users] Create layer from oracle database without spatial data
0uch hwayuyu at yahoo.com.tw
Fri Aug 15 06:43:42 EDT 2008
Thanks very much for your help here.
We finally build the oracle spatial data.
However, we still got the same problem: the layer whatever created by oracle
view or oracle spatial data, it can not be select.
The selection property is correct, but i cant select item ex: building ,
landmark.....
What should I do to make the layer  selectable as the layer create by shp
file?
T.H. Yu.
View this message in context: http://www.nabble.com/Create-layer-from-oracle-database-without-spatial-data-tp18848865p18996760.html
